Question about the GMC 5.3 with AFM
Discussion in 'Chainsaws and Power Equipment' started by ThomH123, Mar 15, 2025.
  1. Chud
    Chud
    I’m killing all of them
    brenndatomu and Chvymn99 like this.
  2. Chud
    Chud
    Duramax revenge
    Erik B, Ronaldo, Ron T and 3 others like this.
  3. Horkn
    I heard my bosses 5.3 in his GMC start up. It had a distinct ticking noise on startup, it went away after a few servings, then when he put it in drive, to take off, it made the ticking noise again and continued to as long as I could hear it.
    Pretty sure what that noise is. He's got to have 150k + miles on it
  4. brenndatomu
    Well past expected lifespan anyways...
    :D
    Horkn, Rothk, Eggshooterist and 4 others like this.
  5. Lehman
    Lehman
    Minnesota
    Most do the eat a lifter and send metal through the block by 80-100000. If this doesn’t do it the in pan oil pump coming apart and giving it the 1-2 punch of no oil and metal shavings probably will
    Horkn, Rothk, eatonpcat and 1 other person like this.
  6. Eckie
    Eckie
    Is there anything that can be done to prevent this? Our suburban is at a little over 100,000 iirc.
    Horkn, Rothk, eatonpcat and 2 others like this.
  7. brenndatomu
    Friends don't let friends drive chebbys...:D
  8. Chud
    Chud
  9. Lehman
    Lehman
    Minnesota
    You can buy a programmer to plug in and it will turn off the cylinder deactivation but at 100,000 miles depending how often you change oil and what oil you use damage may already be done.
  10. Lehman
    Lehman
    Minnesota
    Your choice, fuel pump that could quit like any can or one of 720,000 gm 6.2 gas v-8’s that are a ticking time bomb just waiting to be replaced when they can make them. The Mexican built 5.3 in the Mexican built 1500 is pretty known to fail also there’s a reason Chevy put 800 million dollars into developing a new v-8 and tooling up for it have to see if it’s any better. They all have issues but major engine issues isn’t as great with ford at the moment and the transmission is nearly identical between ford and Chevy. Ford designed the rear drive 10 speeds and gm made the transverse 9 speed that ford programmed out one gear on making it and 8 speed. Think gm has since done the same, looks like both my vehicles are getting a new fuel pump. Oh and I’ve had both gm and ford but both have issues just pick what one you want.
    blacktail, Horkn, Rothk and 4 others like this.
  11. Eckie
    Eckie
    :p
  12. Warner
    You know GMC is an acronym. It ain’t General Motors company…
  13. brenndatomu
    Oh I know it...but I'm trying not to stir the hornets nest, too hard! :rofl: :lol:
  14. Warner
    :chef: Recently a guy was telling me about his new GMC ATwhatever, he went on and on. When he was done I told him I had never heard of it, is it a new hybrid or something ? I wish I had a camera to take a pic of his face. :rofl: :lol:
    blacktail, Horkn, Eckie and 4 others like this.
  15. Jeffrey Svoboda
    Jeffrey Svoboda
    My dad recently bought a GMC Acadia. I told him he got a gay man's Chevy. He didn't laugh. :rofl: :lol::rofl: :lol:
  16. Warner
    :bug::rofl: :lol:
  17. Warner
    Did you ask for his man card?
  18. Eggshooterist
    Eggshooterist
    Erff
    I believe that was addressed several years ago with different ring designs and programming changes so it only runs on 3 cylinders for a maximum of 90 seconds at a time. There are probably some other changes im forgetting. The biggest issue was the cylinders dropping below optimal operating temperatures coupled with the lack of cylinders pressure to help seal the rings. This allowed blow by on the dead cylinders and oil getting up into the combustion chamber. Once all 6 fired up, it burned the oil and over time it ended up sticking rings which compounded the oil burning and actually damaged cylinders in some cases. I read up on it when researching our truck for 3 years before buying one and I'm still active on the Honda forums. It doesn't appear to be a problem anymore and hasn't been for quite some time. However, I'm still going to deactivate it with a plug in device at some point as Its easier on the active motor mounts they use to address vibrations when on 3 cylinders. Why chance needed those replaced.
    Rothk, eatonpcat and brenndatomu like this.
  19. Jeffrey Svoboda
    Jeffrey Svoboda
    :rofl: :lol: I should have! He went from a 14 f250 work truck to that. I'll have to keep it in mind for next time. :rofl: :lol:
    I'm his defense he's had multiple back surgeries. :emb:
    Horkn, eatonpcat and brenndatomu like this.
  20. Eggshooterist
    Eggshooterist
    Erff
    Yep. I had a ford ranger that was an oil burner from new. Not terrible but enough to be irritating. Back then Ford was putting a low oil sensor that alerted you when you were 1/2 a qt down if I recall. Maybe it was a qt. It was one from the early low tension ring days.
    I had a Toyota built Pontiac vibe that was a first year model. They had cold engine clatter and oil burning issues that would usually start around 100,000 +/-. It wasn't just the vibe. It was all 1.8 liter Toyota engines for about a 2 or 3 years span before they changed the piston design.
    As my wife recently said, they all are problematic in one way or another. Might as well buy what you like and hope for the best. Unfortunately, she's pretty spot on.
    ThomH123, JD Guy, Chvymn99 and 2 others like this.
