My next gun!
Discussion in 'The Game Room' started by sirbuildalot, Jun 23, 2025.
  1. sirbuildalot
    sirbuildalot
    Mass
    I have rimfires in both semi auto and lever, pistols only in semi auto, pump shotguns, bolt and semi auto centerfires. The “one” firearm I really still want is a bigger caliber lever gun. I’m torn between 44 mag, 30-30, and 45-70. Im pretty sure it’ll be a Ruger built Marlin. I love my Henry’s, but these new Marlins are gorgeous. I doubt I’ll ever hunt with it due to Massachusetts laws, so it’d be mainly for fun at the range. I like the 44 mag for its higher ammo capacity, “lower” recoil, “cheaper ammo”, and that you could pair it with a revolver. The 30-30 is a flatter shooter once you get out past 150 yards, and has a little more for/a little more pop at that longer range. The 45-70….well I don’t need such a horse of a rifle, but if sure like one! It’s a real stud that’d surely impress the boys round the campfire… that’d be fun to shoot aside from my shoulder and wallet pain. What do I get?
  2. ironpony
    ironpony
    Mid Ohio
    I'd go with the 44 for your stated reasons.
  3. Ronaldo
    Ronaldo
    They all have their place and use. 44 mag will be easier to shoot, cheaper and you can use lower priced and lower recoil 44 special.
  4. Eckie
    Eckie
    The only real way to know which one you like best is to have the trio....
  5. RCBS
    JD Guy, T.Jeff Veal, Ron T and 5 others like this.
  6. Screwloose
    I really wanted a Henry all weather 45-70 but they were unobtainable. Didn't think ammo cost would be much of an issue as how many shots are you you going to get off before the mule kicks your bones loose.
  7. RCBS
    I will have a45/70 at some point. It will wear a suppressor.
  8. sirbuildalot
    sirbuildalot
    Mass
    Well….my next gun ended up being neither. Instead I ordered a Maverick 88, 12 gauge slug gun (rifled barrel). Should be here in about a week and was $320 instead of $1200. Should accompany my 590A1 nicely.
    RichE23ACR, T.Jeff Veal, RCBS and 4 others like this.
  9. chris
    back in the day(WI) when we had a lot of shotgun only areas ( pistols were not allowed yet) I got a savage bolt action 12 ga. These were made by Savage specifically for slugs with a rifled barrel. Basically it was/is a 12 ga rifle, deadly accurate, and even meaner with my handloads as my hand loads were pushing 1750 fps verses the wimpy 1100fps or less factory loads at that time. yes , my pressures were with in spec. as I had a ballistic lab check them. Because the stock was designed as a rifle and not a shotgun , not like a rem 870 that would destroy your shoulder, felt recoil was very light. 1 minute of angle groups at 200 yards ( that is 2" center to center grouping )
  10. Ronaldo
    Ronaldo
    I have a Savage 220, the 20 gauge equivalent of yours, put a Leupold 3-9x40 scope on it and mine is very accurate too. We (Iowa) used to be a shotgun only deer state and these shotgun “rifles” really were popular with hunters here. Now we can use straight wall rifle and handgun cartridges, so the popularity of the slug guns has really decreased.
  11. chris
    Makes a real good bear gun, 2 shots in the clip and one in the chamber.
  12. RCBS
    I've been patiently waiting to see one for under $500. I am a fan of 20ga deer guns. I think they're better than 12's. I used to and still sometimes carry an NEF Ultra slugger in 20ga. Inside 175 yards is meat in the freezer.
    JimBear, sirbuildalot and eatonpcat like this.
  13. Ronaldo
    Ronaldo
    My brother has an NEF ultra in 20 ga and it impressed me so much I wanted one. Ended up with a break action CVA 20 ga rifled slug gun. It shoots very well, my kids started on it and I’ve taken a number of deer with it. I agree with the 20 ga being the sweet spot for slugs!
  14. sirbuildalot
    sirbuildalot
    Mass
    I looked at Savage 212, but it was quite a bit more money than the Maverick, and less capacity. I’m sure it’s a tighter grouping/more accurate gun though. The reviews I saw were hit or miss, whereas everyone raves about the 220.
  15. sirbuildalot
    sirbuildalot
    Mass
  16. Warner
    I heard that before the JIC came out some scoundrels used to buy Mavrick 88’s and cut them down…I would never partake in such activities.
    T.Jeff Veal, RCBS, ole and 4 others like this.
  17. wiguy
    wiguy
    Wisconsin
    I have a few lever guns, two favorites are the Henry 45-70, then the Marlin 357. The Marlin in 357 is short & handy, could fill the role of ‘home defense’ just fine too.
    I’ve been deer hunting in IL for 20 or more years, leased farm North of Peoria. I don’t think there are many years left, farmer mostly retired, land destined to the church, no heirs. I have mostly used one of my tricked out Knight ‘Elite’ muzzle-loaders.
    With the new regulations, I wanted to try the 400 Legend, bought a Savage ‘Trail Hunter’. I put a scope on and collected supplies, used Win-296 powder. So far results have been great, over 500 FPS faster than my M-L. The accuracy is on par with my Knights. My Knights have accounted for SO many deer in IL, coyotes and other varmints. I don’t mind the fiddling and cleaning with the M-L, but thought I’d try the 400 Legend. I used a shotgun a few times but my Knights always did better.
  18. Erik B
    Erik B
    Western Wisconsin
    The only shotgun I have had is a 16 ga Mossberg with a 2 shot mag and a poly choke. No rifling in the barrel. I shot a number of deer with it when WI had shotgun only for the first 2 days of the season before moving on to using rifles the remaining 7 days. Buck or doe first 2 days and bucks only the remaining of the season, unless you had a party tag.
    T.Jeff Veal, eatonpcat and JimBear like this.
  19. WeldrDave
    I'm a HUGE fan of the .35 Remington! I own a couple Marlin .35's and a really versatile, hard hitter!~. They are available and you won't regret getting one!
  20. RCBS
    Some folks may even be clever enough to figure out that a standard buttstock fits on a Shockwave and that a Shockwave barrel fits a standard 590. :sherlock:
