Interesting tool
Discussion in 'Chainsaws and Power Equipment' started by MikeInMa, Jun 22, 2025.
  1. MikeInMa
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    All I can think is that everyone is in such a hurry to..... I don't even know.
    To stack those 2x12s would probably take 2 people and some time to line up perfectly...... all to make 1 quick cut. Probably could've marked and cut them all individually in the same amount of man hours.
    Plus I can't believe that chain puts an equal amount of load on the saw motor as a traditional saw blade.
    Cool idea, I suppose, just not something I'd see myself using.
  3. Stephiedoll
    Stephiedoll
    Omaha, NE.
    x2, plus where is the oiler? Chain won't last long.
  4. Eric VW
    Better used for cutting posts/beams, timber frame style.
  5. The Wood Wolverine
    That was my thought when I first saw it. And the lack of chain lube. :yes:
  6. Dok440
    Dok440
    NorCal
    What the? Why?
  7. RCBS
    A timber framer's best friend next to the 16" circular saws.
  8. eatonpcat
    I noticed when he cut the boards, he slid the blade into an already started cut. Wonder if it is tough to get the saw started in the wood to make a straight cut.
    I will also agree, for heavy timbers it may be better.
  9. buZZsaw BRAD
    Those have been around for years. Used in the timber framing industry. Never have used one.
    How does the chain get oiled?
  10. MikeInMa
  11. Screwloose
    They have been around at least 30 years. Prazzi beam cutter makes square end cuts in large timber.
    Maybe take a look at chain mortisers.
  12. metalcuttr
    metalcuttr
    western WA
    Years ago I used a similar setup for cutting huge glulam beams. We had a coffee can half full of 30 weight oil that we dipped the bar in between cuts. worked fine. We also had a 16" circular beam saw that we used on the purlins.
  13. T.Jeff Veal
    Yep, beam cutter, plus lighter than the 16" saws.
