OWB Shop Heater
Discussion in 'OWB's and Gasification Boilers' started by lukem, Jun 5, 2025.
  1. lukem
    After all these years I'm FINALLY ready to hook the OWB up to the shop. Any recommendations on heat exhanger / fan units? I'm heating about 1,000 sq ft of moderately insulated space.
  2. yooperdave
    Anything on craigslist or marketplace near your area?
    What inside temp are you hoping to get?
  3. lukem
    Nothing good for sale used.
    I only want to be able to keep it 60 degrees on a 10 degree day. Any warmer inside or colder outside in probably going to find something else to do.
  4. Horkn
    Are you thinking like a modine style heater? Just not needing any heat to be made in the unit, just a heat exchanger with a blower?
  5. yooperdave
    Exactly.
  6. Screwloose
    I know amateur cutter has some in his shop. I have seen some really nice systems made from vehicle radiators. The older style with flanges on the side makes it easy.
  7. brenndatomu
    Beat me to it... I've seen some very affective shop heaters made up of an old car/truck radiator with a box fan zip tied to it, on/off controlled by one of those stand-alone 120v thermoswitches :yes:
  8. Horkn
    Right? Why overcomplicate things. That would work great.
  9. lukem
    I've considered making my own, but honestly don't really have the time or energy to find the right mix of radiator surface area and airflow to deliver the right amount of BTUs per hour. Calculators say 50K BTU will be more than plenty...and I'd rather have a small unit that runs a lot than a big unit that cooks you for 1 minute then freezes you, and repeats. I'd rather spend a couple extra bucks and pull something out of a box and run it.
    I do know I'm just going to run a wifi plug with a thermostatic plug sitting on top of it. That way I can turn on the heat in the morning from my phone to warm it up.
  10. lukem
    Still need to plumb it in but that's easy. Past experiences tell me I need to be able to bleed air so that's why I went with those 90s.
    The thermostat location is probably too high, but it will still work and look at little cleaner.
    fuelrod, RCBS, T.Jeff Veal and 8 others like this.
  11. lukem
    Looks like its going to get cold enough this weekend to actually turn this thing on. Curious to see what it can do. I've ran it a few times for a few minutes and it seems like it puts out plenty of heat. I'm only looking to keep it about 60* in there when I'm working and 45 when I'm not.
  12. lukem
    It was about 20 degrees this morning and I took the shop from 43 to 62 in under an hour. That's good enough for me. Definitely cycles the boiler more though. Oh well, firewood grows on trees.
    fuelrod, Chaz, yooperdave and 4 others like this.
  13. Horkn
    Well, you're putting it to a good test now. Is it supposed to get colder tonight for you in Indiana? This am was shock here in Wisconsin.
  14. lukem
    It was supposed to be 10 here last night but only got down to 20. Forecast is 7 for tonight.
  15. lukem
    It's barely above 0 and the heater is cycling about 50% of the time to keep the shop at 60. Really happy with this setup.
    fuelrod, RCBS, Chaz and 5 others like this.
  16. monko
    monko
    pa
    Just my experience, I had a similar setup and moved it from high on the wall to sitting on the floor and it was night and day difference. Was heading a 30x30 shop at the time
  17. yooperdave
    Nice!
    But there is always that extra room needed for sumpin else.
    brenndatomu likes this.
  18. lukem
    I considered that and still may do it in the future. Most of the time I have a second filter fan running anyway and it helps circulation.
    yooperdave and brenndatomu like this.
