New to me - tree leaves
Discussion in 'The Wood Pile' started by MikeInMa, May 18, 2025.
  1. MikeInMa
    Red gum, water oak, and pin oak in Georgia. As identified by the "Picture this" app.
    File under - You know you're a hoarder when...
  2. buZZsaw BRAD
    I recognize only the gum out of all three. I've heard T.Jeff Veal mention water oak. The pin oak around here has the typical red oak leaves only "dainty" based on my observations.
    Im a hoarder too Mike! Actually more of a tree nerd. :nerd: :emb:
  3. Chud
    Chud
    The last pic is Willow Oak
    The first pic is sweet gum and I’d id the 2nd as Laurel oak
    Pin Oak
    ThomH123, billb3, jrider and 6 others like this.
  4. MikeInMa
  5. Chud
    Chud
    I’d say 98% of locals would call it Pin Oak. Swamp Chestnut is way off and the developer’s should be fired.
  6. JD Guy
    JD Guy
    Upstate SC
    Never heard of or seen red gum around here so I have to go with sweet gum, water oak and pin oak.
    buZZsaw BRAD and MikeInMa like this.
  7. T.Jeff Veal
    It's nice you found something different down here. I did the same when we went to Michigan and PA.
    The gum is sweet gum and the leaves will turn very red in fall... 20241025_101025.jpg
  8. jrider
    jrider
    1st pic is sweet gum. Pretty sure red gum is an Australian wood. 2nd pic not sure of. 3rd pic is willow oak which should never be confused or called pin oak in my opinion as pin oak is a whole different variety.
  9. billb3
    Yes, pin oak leaves usually have deep fissures.
    The pin name comes from the appearance of the branches on the trunk - sticking out like many long pins.
    The bottom branches tend to droop down. I've had to cut all the bottom branches on some of the ones I planted many years ago so I could cut the lawn.
    Interesting that the willow oak has pin oak in some areas as a common name.
    There's plenty of common names for trees around here that are just plain wrong. But most of us know what most of us are talking about. Diversity can be fun like that.
    jrider, Eckie, MikeInMa and 2 others like this.
  10. MikeInMa
    You mean, an app on the internet is inaccurate? Well, gosh golly gee.
    :D
    Thanks for all the input/corrections!
    jrider, buZZsaw BRAD and T.Jeff Veal like this.
  11. Canadian border VT
    I will confirm red gum is Australian wood
    Beautiful dense..
    JD Guy, T.Jeff Veal, jrider and 3 others like this.
