CS-590 weak oiling
Discussion in 'Chainsaws and Power Equipment' started by Rothk, Apr 13, 2025.
  1. Rothk
    Rothk
    WVA
    Recently, I've noticed the chain getting very little oil during cutting. I took the bar off to check the oiling and saw nothing coming out of the slot. With the guide plate (32) off, I can see some oil trickling out of the hose (1) at WOT, but little if any oil makes it to the bar. Changing the adjustment settings had no discernible impact.
    Before I take the whole thing apart - do any of you have some suggestions for the likely culprit here? Thanks.
    eatonpcat and John D like this.
  2. Ronaldo
    Ronaldo
    Plugged filter at pickup hose, tank vent plugged or partial plug, lines to pump kinked or split or faulty pump. All are possible causes.
  3. Rothk
    Rothk
    WVA
    I got my work cut out for me!
    eatonpcat, John D and Chud like this.
  4. John D
    John D
    Syracuse ny
    The one thing I do with all my bars is open the oil hole on all my bars
  5. Canadian border VT
    Could be worm drive worn. Looks like screw goes from bar oil chamber to chain had that happen on jonsered
    John D and Rothk like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    I like the KISS method. Id start with draining the oil tank and making sure the filter and line isn't plugged then go from there.
    Rothk, eatonpcat, Ronaldo and 3 others like this.
  7. John D
    John D
    Syracuse ny
    X2 start hear
    Rothk, eatonpcat and Eggshooterist like this.
  8. Eggshooterist
    Eggshooterist
    Erff
    I bought a vintage homelite saw of the local online auction that wouldn't oil. It was plugged from the filter out to the bar pad. Lol. The filter had deteriorated and let the fines pass through.
    I keep a soft bristle brush with my saw kit to get at much of the debris off from around the caps before opening them. It only takes a few seconds and will save me a headache later.
    Mrxlh, John D, Rothk and 4 others like this.
  9. Rothk
    Rothk
    WVA
    Filter is squeaky clean. I'll take a look at the oil pump once my clutch removal tool shows up in the mail... :whistle:
    eatonpcat, John D and Ronaldo like this.
  10. Rothk
    Rothk
    WVA
    Got in there tonight. Very dirty on the inside. Hoses and pump look ok from what I can tell, but the collar (item 10 in the diagram below) looks like it was made from plastic and was disintegrating. Replacement parts are on the way.
    I will say this about the CS-590. It's a lot of saw for the money, but I have had more parts breakages and down time than I would have liked. It seems like I spend as much time working on the saw as cutting with it.
    RCBS likes this.
  11. RCBS
    Thanks for reminder. I need to grab a couple of these for my Makitas.
  12. Rothk
    Rothk
    WVA
    Old vs. New:
    I will put it back together later today.
    Remember kids, heat kills.
    RCBS, John D and Eric Wanderweg like this.
  13. Rothk
    Rothk
    WVA
    We have oil!
    ...and it seems to be getting to the chain pretty good. There is some dripping/weeping in the clutch area. I'm not sure what I can do to fix that...
    John D and RCBS like this.
  14. Eggshooterist
    Eggshooterist
    Erff
    Every saw I've owned / own will have oil dripping from the clutch cover area because it gets slung all around the inside of it.
    John D, Ronaldo, Rothk and 1 other person like this.
  15. RCBS
    I use these. Some are worse than others, but they all 'leak'.
  16. Eggshooterist
    Eggshooterist
    Erff
    The pig mats are great. You reminded me I need more. Lol
    John D, RCBS and Rothk like this.
  17. RCBS
    They are laying under all my saws and have greatly reduced the 'horsepower sweat' issues.
    John D, Rothk and Eggshooterist like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    I usually used cardboard but have switched to them. Much better.
    John D, Rothk and RCBS like this.
  19. RCBS
    I'll admit that old bath towels used to sit under mine. The diapers work much better and are cheaper to replace.
