Oh &#@$ me!! What's next?!?!!!
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, Apr 19, 2025.
  1. Screwloose
  2. Eric VW
    :eek:
    The hydraulic hose repair shop, I guess. :D
    Hope that oil wasn’t piping hot, Keith!
  3. Screwloose
    It was pretty warm and smelly. Gave me a bruise through 2 shirts!
  4. Horkn
    Crazy, it gave you a bruise through 2 shirts? Wow!
    Any sign of the hose going before it blew?
  5. Screwloose
    Weeeeell it had some surface checking!
    I can only blame myself for not changing them out, always sumptin more pressing.
    Bought it New in 1980! They held up well.
  6. brenndatomu
    Well, sure glad it wasn't hotter, and that it didn't go through your skin, as it certainly can, which I understand is a pretty serious injury!
    I'd say 45 years is a pretty good run!
  7. Canadian border VT
    Note to self check after 30 year!!
  8. Rope
    Rope
    Alaska
    Can’t like that, I’m glad you’re okay. High pressure oil injected into the body has quite a few unique issues. Glad you find out first had.
  9. eatonpcat
    That sucks Keith, glad it wasn't worse!
  10. Chvymn99
    X 2 … :bug:
  11. The Wood Wolverine
    Dang, glad it wasn’t screaming hot!
  12. Stephiedoll
    Stephiedoll
    Omaha, NE.
    As others have said, glad it wasn't worse and good luck with the repairs.
  13. Chaz
    Chaz
    Southwestern NY
    Glad it wasn't worse as well Keith.
    :bug:
  14. The Wood Wolverine
    Welp, dad and I just happened to get sprayed a while ago too. Not nearly as bad, basically a light shower. I got to the throttle quick.
    Glad we weren’t on the other side!
  15. Rope
    Rope
    Alaska
    Can’t like that either. Glad yous guys are okay. Is that considered cheating to have fire starter on the splits/ seasoning?
    JD Guy, Horkn, T.Jeff Veal and 8 others like this.
  16. Rope
    Rope
    Alaska
    High pressure hydraulic oil does make a mess. I have seen large equipment have hose breaches. Wow what a mess.
  17. The Wood Wolverine
    Lol. We could sell it as match light firewood.
    What fluid got on the muffler started a fire quick, glad it didn’t last long.
  18. JRHAWK9
    JRHAWK9
    Wisconsin
    Yikes! That would have sucked!
    One of the reasons I pull mine in the garage after I'm done using it for the day. I want to limit the UV exposure to the hoses. It's only sitting outside when it's being used.
    40+ years is impressive!
  19. brenndatomu
    Wow, another oil bath! Glad nobody was hurt.
    Is that the oil filter gasket hanging out that I see there?
    Think it was a lil loose, or just too much back pressure with that filter inline there?
  20. The Wood Wolverine
    This was the first time I ran 100% throttle w/ the new pump, I usually back down from max a small scoch. Definitely filter o-ring but I'm unsure if that's all. In the first pic I posted, is that threaded hole supposed to have a plug of some type? I don't recall noticing it during the relocation.
