Off brand carburetors
Discussion in 'Chainsaws and Power Equipment' started by Sicilian Suspect, Mar 16, 2025.
  1. Sicilian Suspect
    Sicilian Suspect
    Savannah Georgia
    Picked up a saw this weekend at a flea market that’s missing the carb. Curious about the no name carbs online that run anywhere from $11 to $21 vs OEM that’ll set you back $75/$85.
    This is for a Husky 55.
  2. Eric Wanderweg
  3. Sicilian Suspect
    Sicilian Suspect
    Savannah Georgia
    metalcuttr, brenndatomu and MikeInMa like this.
  4. Eric Wanderweg
    I’ve had some good luck on eBay from time to time. Better act now; there’s less than 3 1/2 hours left on that posting ;)
  5. Dok440
    Dok440
    NorCal
    I agreee the aftermarket carbs are hit or miss. I have had far fewer that worked perfectly. Most work with some issues and some can never be tuned to work right. I would listen to Eric and grab that used carb!
  6. cezar
    cezar
    KY
    Does anyone know WHY aftermarket carbs are so bad? It doesn't seem like the tolerances should be that hard to hit. Something to do with the rubber compounds in the diaphragm or something?
    I put a chinese carb on my push mower and it definitely works but not nearly as well as the original one.
  7. Skier76
    Skier76
    CT and SoVT
    I’ve gotten lucky with two Amazon carbs; one for a Poulan string trimmer and the other for a Tecumseh snow king. Both work excellent and I’d say the engines run better than they did before.
  8. brenndatomu
    Well they manage to screw up things a lot less complicated than a diaphragm carb, so no surprise to me! I'm more surprised that some of them actually do work ok!
    metalcuttr and Eric Wanderweg like this.
  9. Eric Wanderweg
    That was my experience about 6-7 years ago with a carburetor I bought for my old Simplicity snowblower. I put it on, it started first pull and I never fiddled with it right up until the time I sold that machine 2 years ago. For $15 I was dumbfounded. But that seemed to be the exception to the rule and the couple others I bought for various engines ran less than optimal.
    metalcuttr, brenndatomu and Skier76 like this.
  10. Eggshooterist
    Eggshooterist
    Erff
    Hipa is the only aftermarket carbs I've had 100% success with so far. I would still go oem if it were my quality ope.
    metalcuttr and brenndatomu like this.
  11. Mrxlh
    Mrxlh
    Dat Boot
    OEM only on carbs is my take, if you are getting into the saw gig, get a small ultrasonic cleaner. Unless a carb has ethanol corrosion damage, you can get them clean with an ultrasonic and just re-kit them and be good to go. The 55 (and all its variants) were plentiful, don’t be scared to hit eBay or any of the used parts saw shops up.
  12. Mrxlh
    Mrxlh
    Dat Boot
    My opinion is that the Walbro WT 170 is better than the Zama. My 55 has the Walbro and it has only had 2 kits in it since 1996 and still tunes flawlessly.
    metalcuttr and Eggshooterist like this.
  13. Reloader
    Reloader
    NW Oregon
    I’ve purchased a couple of after market carburetors for Shindaiwa blowers. One arrived and the bolt holes didn’t line up.
    Got a different one at a later time and it fit right and so far is running great.
    brenndatomu likes this.
