Measuring rounds
Discussion in 'Chainsaws and Power Equipment' started by Cold Trigger Finger, Feb 16, 2025.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    This is how I do it . IMG_20250121_104545_HDR.jpg IMG_20250121_104523_HDR.jpg
    The bent wire on the 251 is attached to a Super strong magnet . It measures 16" wood . The All thread rod that goes through the hole in the bar of the 193T is adjustable . At the moment it's set for 18" wood. But is adjustable for out to 36" wood .
  2. ironpony
    ironpony
    Mid Ohio
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I do it similar. Rod on a magnet attached to my bar. I've got mine set for 16" which fits both my stoves.
    My name is Mike, and I'm a hoarder.
  4. Eric Wanderweg
    Similar system here. I have a homemade marking stick on a magnet. It’s set for 16” but I have notches at 14,16,18, and 20”. Awesome tool to have when dealing with long logs.
  5. Dunmyer mowing llc
    Dunmyer mowing llc
    Huh,good ideas.
    I always just scratch a mark in the bar at 16"
  6. The Wood Wolverine
    I’m a Mingo Marker fan.
  7. buZZsaw BRAD
    Simple and effective.
    Folding ruler and chalk used here.
  8. MikeInMa
    Yardstick and chalk gets it done here
  9. RCBS
    Yeah I do it the hard way with a cheap tape and some paint. I'll call it scaling. lol
  10. buZZsaw BRAD
    Dont you mean yadstick? :whistle:
  11. MikeInMa
    Yahdstick :thumbs:
  12. RCBS
    Are Pizza & Fries really a thing over there? (Lady from Somerville was telling me about one time)
  13. MikeInMa
    Maybe closer to Boston. Not a thing where I am out in the burbs. Never heard of it.
  14. Locust Post
    If and when I feel like measuring and marking I use a tale and automotive marker. Most times I just eyeball it. My stove will take a pretty long split and I end up coming pretty close to 16" to 18" my stacks aren't as pretty as some but it burns.
  15. Elm-er Fudd
    Elm-er Fudd
    Kansas
    If I was selling wood I would measure it. Too much work to sell it for what I could get for it, so I just eyeball it as well. Like you said my stacks are not pretty either, but it all makes heat. Going to quit stacking this year as well. Unlimited amount of IBC totes for free, so going to build several 5 cord cages and toss it in. Also going to make a few raised bed gardens out of half totes this spring.
  16. Rope
    Rope
    Alaska
    Pro-sizer, nice little compact laser that bolts to the handle. Works great, battery lasts well in the cold. USB charger. Huge time saver and it out of the way.
  17. Cold Trigger Finger
    Cold Trigger Finger
    Do people Not get an Overload of carbs from pizza OR fries ????
    I can see pie and ice cream . Or cake and Ice cream . But pizza And fries . I yi yi . !
  18. Cold Trigger Finger
    Cold Trigger Finger
    I needed something fast and accurate last year for a customer that wanted exactly 16" wood . And had another order for 18" wood . So the all thread , fender washers and nuts .
    The bent wire and magnet one , a friend made up and gave me .
  19. buzz-saw
    buzz-saw
    Ct.
    16 inch piece of white PVC pipe (white makes it harder to lose) and either a lumber crayon or piece of chalk.
  20. eatonpcat
    Not if you are cutting in the snow!! :p
