Husqvarna 550xp will not autotune
Discussion in 'Chainsaws and Power Equipment' started by Unclefish, Jan 21, 2025.
  1. Unclefish
    Unclefish
    Northeast
    Well I have tried to reset my 550 this year. Let idle for 5 minutes did the 3/4 throttle tip in log it never smooths out. It still runs and cuts OK just sounds like it's always hunting. Up and down on the full throttle. Starts hot or cold no problem and really does not bog out in a log. I have always run the premixed good gas in it. It also idles perfect.
    Also it's a Mark ii bought Jan 2022
  2. John D
    John D
    Syracuse ny
    Does it hunt while cutting?
    If. It I probably wouldn’t worry about it
    Lastly if the dealer is close maybe stop by and ask them to set the saw
  3. RCBS
    If you still got warranty take it in. Could be an air leak messing with the carb.
    Bjorn, metalcuttr, Screwloose and 6 others like this.
  4. The Wood Wolverine
  5. SimonHS
    SimonHS
    Yorkshire, England
    After the idle period it has to be full throttle under load, like the clip below.
    metalcuttr, Screwloose, Chud and 6 others like this.
  6. Unclefish
    Unclefish
    Northeast
    I will try it again. I can clearly hear it in video when it adjusts. I did my 562xp and it still has been good since I did it back in 2019.
    I saw a post on another site about the diaphragm going bad 550 style carb. And also air leak on the way they put carb on the saw. But if it was that should have done it since new.
    Thanks for replys
  7. John D
    John D
    Syracuse ny
    Don’t forget do not run the auto tune saws out of fuel
  8. Unclefish
    Unclefish
    Northeast
    I try not to. It's hard enough to remember to pull the starter cord out 2 to 3 inches to before I shut it down also. Which I never new about till I just had to replace the starter pulley on my 562xp. And its funny the 550xp actually pulls the cord right out of my hand 562xp barley pulls at all.
  9. huskihl
    huskihl
    Like mentioned, you need to bury enough of the tip to where it’s putting a load on the saw and make a continuous wide open cut for 2–3 minutes without changing throttle position. Somewhere around 60-90 seconds straight it will start to adjust
  10. Unclefish
    Unclefish
    Northeast
    I did this yesterday during my lunch break . I could here it start to autotune then it started sputtering towards end. I cut a couple pieces seemed to be ok. I will put it to test this weekend when I bring up a few log lengths from down back to the split pile. Thanks
  11. Unclefish
    Unclefish
    Northeast
    Thank you.. the 550xp ripped up shop again. No hunting today. Only cut up 2 log lengths of wood today. Spent the day splitting. Did some big stuff and the nasty knotty crap and y chunks today. Got another cord plus of stuff that I normally would just burn in the burn pile. Might as well put it to use even though it seems to kick my azz.
  12. Haftacut
    Haftacut
    Rives Junction, MI
    My 550 xp may be my favorite saw. Very pleasant to run
    RCBS, metalcuttr, John D and 3 others like this.
  13. Haftacut
    Haftacut
    Rives Junction, MI
    Went to start my saw (550xp) the other day and it will only stay running on full throttle. Set it aside for a couple days now. Blew all the crap out from under the cover. Fuel lines look good. Cleaned the air filter. No improvement. I’ve heard they have a reputation for crank seals going bad. I’m thinking of having the dealer plug it in to see if it’s an auto tune issue. If the auto tune checks out, would the next step be to vac test the crank case, or possibly just easier to go ahead and change the seals and see if my problem goes away? Love the saw and need it back in the arsenal!
    RCBS likes this.
  14. John D
    John D
    Syracuse ny
    If you have a really good dealer and he has been around for a while might as well drop it off and let him fix it
    Haftacut likes this.
  15. RCBS
    Fuel filter good to go? Intake line free of cracks/pinches? I would be sure to eliminate all the rudimentary before changing crank seals. If your output seal is leaking, you probably need a bearing also. I've had some issues with my mki, but it has never failed to start and idle.
    Haftacut, John D and eatonpcat like this.
