Husqvarna 254 XP chainsaw
Discussion in 'Chainsaws and Power Equipment' started by Abe Romi, Jan 4, 2025.
  1. Abe Romi
    Abe Romi
    Morris county New Jersey
    I have a Husqvarna 254 XP and it's been sitting for quite a while and I'd like to know if anyone can help me find the part number on the carburetor so I can swap it out. It stopped oiling about 7 years ago so I thought it was an internal problem but it turned out that switching to a 20-in bar was the cause because the bar was the wrong one. So I fixed that problem but now it doesn't idle.
    tamarack, SimonHS, eatonpcat and 3 others like this.
  2. The Wood Wolverine
    tamarack, eatonpcat, John D and 2 others like this.
  3. Abe Romi
    Abe Romi
    I tried this site it only gives me the carburetor number for the 254 not the XP version so I'm not sure if I order it it will work and it is not cheap they want $275 for the carburetor so I don't want to make a mistake.
    eatonpcat, John D and Screwloose like this.
  4. Chud
    Chud
    Partstree is another site I’ve used for older Husqvarna parts. I’d also google carb for 254xp. You might could find a used one.
  5. The Wood Wolverine
    Pull the old one and order as such. There are identifying numbers on it, that way you’re sure to get the right one.
  6. Eggshooterist
    Eggshooterist
    Erff
    Is the carburetor ruined beyond just cleaning and replacing the diaphragms and gaskets?
    eatonpcat, M2theB, John D and 3 others like this.
  7. Abe Romi
    Abe Romi
    Thanks for your help guys I'm going to take it apart and get the number off though carb and start there.
  8. M2theB
    M2theB
    Central Massachusetts
    not necessarily
    Aside from gasket and diaphragm, replace the needle, pull welsh plugs and clean all ports as best you can with carb cleaner and parts cleaner if available
    eatonpcat, buZZsaw BRAD and Warner like this.
  9. RCBS
    eatonpcat likes this.
  10. Farmchuck
    Farmchuck
    Nepa
    I believe all 254 saws were xp The 200 series saws were the professional line at the time hence the xp xtra power.
    Off course I have been wrong before.:)
  11. tamarack
    tamarack
    paulina oregon
    254XP is a great old saw. Certainly worth fixing!!
    Farmchuck likes this.
  12. Farmchuck
    Farmchuck
    Nepa
    You got that right !
