Wood Splitter
Discussion in 'Chainsaws and Power Equipment' started by HUBER, Sep 26, 2014.
  1. HUBER
    HUBER
    looing for some wood splitter plans for a 25-30 ton Horizontal / vertical
  2. jetjr
    jetjr
    Pa/Md line
    @HUBER do you have access to parts to build one or would they all have to be purchased?
  3. HUBER
    HUBER
    Hi, I have the tools, space and material just looking for a proven plan for guidance. Thanks!
  4. the GOAT
    the GOAT Banned
    If your building a horizontal/vertical splitter you can go to any box store and look at what they have for ideas. But you won't save much money.
    If you really want to build your own look at the timberwolf and built rite horizontal splitters with a log lift and four way for ideas -- a much better design then the typical box store splitters in my mind.
    coal reaper and jetjr like this.
  5. HUBER
    HUBER
    Thanks for the advice, i will look up timberwolf
  6. lukem
    Do you already have a pump engine or cylinder?
  7. HUBER
    HUBER
    Hi, I dont have those items yet ...
  8. jetjr
    jetjr
    Pa/Md line
    You will have a pretty fair amount of money tied up in those 3 components plus the valve and hoses. I built mine using a homemade 3pt splitter and an old riding mower that I had. Don't know the tonnage but splits most everything I throw at it one way or another. If you want I'll post some pics later.
  9. cutforfun
    cutforfun
    Horizontal only. I went with a wedge on ram for the wood I split. Lots of good ideas in the splitter pic thread IMG_20140517_193816953.jpg IMG_20140518_142208931.jpg
  10. the GOAT
    the GOAT Banned
    I'm building a horizontal splitter with log lift, adjustable log lift, auto cycle and 5x30" main cylinder. The hydraulic side of things will be 1500-2000 if I buy everything new. Another $3-400 for steel. And then tires, hubs etc. and an engine.
  11. jetjr
    jetjr
    Pa/Md line
    @Mike From Maine Wow that's big money. I picked up the 3pt for $200 and had the riding mower. Bought a pump off eBay and tank from northern. Got around $500/$600 in it. No log lift though. Been reading you thread about your build good lick.
  12. the GOAT
    the GOAT Banned
    I thought about converting a 3pt splitter as well... There was just one here on cl for $400 but it didn't have a big enough beam or cylinder for my taste.
    The valves, pump, tank and cylinder for a tw6 are easily over a grand... Not cheap but building it myself. But still a lot better then what they want for new one. And I can make a few custom modifications that will work better for my needs.
    http://www.alexequip.com/product/timberwolf-tw-6-log-splitter/
    DexterDay and jetjr like this.
  13. chris
    Just a though , as almost everyone likes to use H or W beams, I went a different direction after bending and twisting one. 2, 4"x 6" x 1/4" walled tubes welded together makes a super strong beam- could even use one or both as the tank. I have not been able to destroy it yet
    MasterMech, the GOAT and DexterDay like this.
  14. the GOAT
    the GOAT Banned
    The wallenstein processors use a similar setup... But they don't weld them together. They leave a small space in between for the wedge and the push plate to ride in.
    I ended up going with a single 6x8x1/2" tube which is also less likely to twist then a tall h beam.
    Edit/ they also use tube instead of a beam on some of their smaller splitters.
    MasterMech likes this.
  15. jetjr
    jetjr
    Pa/Md line
    Mines built on an old piece of railroad track. No twisting or bending there.:p
