What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. buzz-saw
    buzz-saw
    Ct.
    Shiny aluminum it does not play well with. Plus, I sprayed it on straight and really let it sit so that probably did not help either.
    John D, Bigadbob and Eggshooterist like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    That explains it lol. The instructions warn against using it undiluted on aluminum.
    John D and Bigadbob like this.
  3. buzz-saw
    buzz-saw
    Ct.
    Instructions ; LOL never heard of such a thing.
    Well now I know.
  4. Eggshooterist
    Eggshooterist
    Erff
    I originally bought it to clean our bike chains, derailleurs and sprockets. I had to dilute it to protect the aluminum rims ect.
    John D, buzz-saw and Bigadbob like this.
  5. J. Dirt
    J. Dirt
    What’s on the bench?…..
    What’s under the bench is the question? If anyone can spot it.. IMG_0153.jpeg
    John D, Eggshooterist and Dok440 like this.
  6. MAF143
    MAF143
    North Central OH
    a dirty water pump, a Poulan / Craftsman saw, and a Husky in a box...
    And way over in the corner is the missing circlip that sprung out of the toasted piston coming out of the MS391 I'm working on at my bench!!!
  7. buzz-saw
    buzz-saw
    Ct.
    Someone needs a bigger bench.
    John D, J. Dirt and Eggshooterist like this.
  8. J. Dirt
    J. Dirt
    I’ll bet there’s a circlip or two around somewhere!
    That’s a minty echo 7310 in a box that I need to finish up. Someone bought it brand new and decided to “port” it and ruined the p/c. Looked like they went after it with a wood rasp! o_O
    John D, Eggshooterist and MAF143 like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Sounds like an Iron Horse disciple. Lol
    John D, J. Dirt and MAF143 like this.
  10. SierraMatt
    SierraMatt
    Prince Edward County
    20241219_191259.jpg Picked this up the other day. Has the HDA 87 carb and KS cylinder. She's a runner with lots of compression, she just needs a few little things...but sourcing the small parts is part of the fun!
    Mrxlh, Chud, John D and 6 others like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Sweet saw.
    John D likes this.
  12. ammoaddict
    ammoaddict
    Granite Falls, NC
    Nice
    John D likes this.
  13. Eggshooterist
    Eggshooterist
    Erff
    My 011. Breaking it down to fix the leaking gas into bar oil tank problem.
    Ran on 25:1 Amsoil Dominator since I did a little exhaust port work.
  14. Eggshooterist
    Eggshooterist
    Erff
    Nephew won this at the local online auction. It was a traverse city Michigan DNR saw. He wanted it muffler modded and sharpened. Semi chisel. The saw is in really good shape. Same saw as the Homelite 360 but the Canadian built version according to what I found online. 20241222_151724.jpg 20241222_151758.jpg
  15. Eggshooterist
    Eggshooterist
    Erff
    The muffler had a V shaped baffle right at the inlet. Now gone. 20241222_153325.jpg
    Chud, John D, Ron T and 2 others like this.
  16. Eggshooterist
    Eggshooterist
    Erff
    Skier76, John D, Ron T and 1 other person like this.
  17. John D
    John D
    Syracuse ny
    Bought this for 40 bucks guy thought the carb was shot all I did was put fresh fuel in it and adjusted the carb IMG_3797.jpeg IMG_3796.jpeg
  18. Eggshooterist
    Eggshooterist
    Erff
    Back on the Stihl 011. This thing is lucky it has sentimental value...
    As a refresher, it was leaking fuel into the bar oil. The tanks are stacked and seperated by a thin wall of magnesium and the crankcase gasket. I love loose roller bearings...NO! No I do not.
    John D and MAF143 like this.
  19. Eggshooterist
    Eggshooterist
    Erff
    Of course the gasket for the reed block was hard and brittle. Gasket material to the rescue. 12905021-13cf-40f8-80cf-45d6c5fe332a.jpg c711126a-c63d-4b4b-b31e-323ae296dc61.jpg 835f58a4-584b-4bdb-94f0-9b1de1f4ff1e.jpg
    Mrxlh, John D, MNWood and 3 others like this.
  20. Eggshooterist
    Eggshooterist
    Erff
