What's on your bench now?
Discussion in 'Chainsaws and Power Equipment' started by Czed, Jun 29, 2020.
  1. MAF143
    MAF143
    North Central OH
    I just got the piston and seals for the 291 I'm working on. I still have some clean up to do before assembly. I'll dress the bar and sharpen the chain for him also. The bar is burred pretty bad, you don't want to drop it around anything you don't want sliced up pretty good. Wicked burrs on it. I'm not a fan of used motor oil being used for bar oil...
    We're busy all the rest of this week so It'll probably be a few days before I can get back to it.
  2. farminkarman
    farminkarman
    Neenah, WI
    Dyed some flippy caps and throttle lockout lever black for my 2171. IMG_8707.jpeg
  3. Eggshooterist
    Eggshooterist
    Erff
    They put new lines, carb kit and later model electronic ignition coil in it. Still wouldn't run. Lol
    John D, Dok440, Bigadbob and 4 others like this.
  4. Eggshooterist
    Eggshooterist
    Erff
  5. MAF143
    MAF143
    North Central OH
    Glad you were able to figure that one out... Carb issues are always a bear... unless they aren't...
    :doh:
    John D, brenndatomu and Eggshooterist like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    That was the first time I've seen that. Who knows what else I run into with the rest of them.
    brenndatomu and MAF143 like this.
  7. Eggshooterist
    Eggshooterist
    Erff
    MNWood and Eric Wanderweg like this.
  8. Eric Wanderweg
    I just got the 028 back together. New 028 super top end, and while I was in there I replaced the impulse line and the crank seals. Ready to test it out soon on some dead red oak.
    buZZsaw BRAD, Chud, Ron T and 6 others like this.
  9. Eggshooterist
    Eggshooterist
    Erff
    Looks spiffy bud. :yes:
    Bigadbob, John D and Eric Wanderweg like this.
  10. Eggshooterist
    Eggshooterist
    Erff
  11. ammoaddict
    ammoaddict
    Granite Falls, NC
    John D and Eggshooterist like this.
  12. Eggshooterist
    Eggshooterist
    Erff
    My new to me 501P. Came with an 18" Tsumura light bar and 3, full chisel woodland pro chains. 2 still in their boxes. Canadian made chains even. All
    Freeeeee.
    John D, Dok440, Bigadbob and 3 others like this.
  13. Ohio
    Not Ohio
  14. Eggshooterist
    Eggshooterist
    Erff
    It is spotless on the parts of the walls I can see. You can still see the machine marks when zooming in. That saw is a heavy use saw that has 100-150 tanks through it doing some ground work for an arborist and bunch of fire wood cutting. Ran on original Red Armor, Dolmar synthetic or Amsoil Dominator its whole life, with the majority of it RA and Dolmar oil @ 40:1.
  15. Ohio
    Not Ohio
    Yeah I looked at it and was like there isn’t a single machining mark. Then I zoomed in and all was well. I’m getting a 501p here soon.
    John D, Bigadbob and Eggshooterist like this.
  16. Eggshooterist
    Eggshooterist
    Erff
    Cool. It looks and feels well made. Old school build quality yet light weight.
    John D, Bigadbob and Ohio like this.
  17. buzz-saw
    buzz-saw
    Ct.
    Yes sir , That is Minty=fresh.:thumbs:
  18. Eggshooterist
    Eggshooterist
    Erff
  19. buzz-saw
    buzz-saw
    Ct.
    Watch that SuperClean on aluminum , it could turn it white on you. I tried it on some wheels a while back and it didn't turn out too good.
  20. Eggshooterist
    Eggshooterist
    Erff
    I've done several cylinders with it. It just made them darker in color. Never tried smooth or shiny aluminum though. I do have it diluted significantly.
    Mrxlh, John D, Bigadbob and 2 others like this.
