Echo pole saw
Discussion in 'Chainsaws and Power Equipment' started by fuelrod, Nov 9, 2024.
  1. fuelrod
    fuelrod
    Western Maine
    That's a chainsaw right?
    I'll see what's easier on the ragged out shoulders. I do have a nice cordless (manual:rofl: :lol:) pole saw that's very quick, sharp and light and I can see using both depending on what I'm trimming.
    I didn't opt for the extendable model, it's 17.4 pounds vs 13.2 for the one above. (PPF 2620)
    This one has a fixed length of 96" where the adjustable one goes to 12'.
    I've only made a few cuts with it. It's rifle season here and I have some friends in my woods that I don't want to disrupt. :thumbs:
    Ohio, Eric Wanderweg, RCBS and 10 others like this.
  2. Dok440
    Dok440
    NorCal
    I have the extendable version. It is quite heavy compared to the Husky. Works great. Your shoulders will feel it!
    RCBS, eatonpcat, Chaz and 5 others like this.
  3. Eckie
    Eckie
    I've been meaning to get a pole saw. I'm typically a stihl man. Buy I did get an echo battery saw and really like it. I'm probably going to get the extendable version of whichever I pick. Are the echos supposed to be good?
    John D, eatonpcat and Chaz like this.
  4. JimBear
    JimBear
    I believe they are, I have had no issues with mine.
    John D, RCBS, Eckie and 2 others like this.
  5. RCBS
    I finally got one a couple years ago. Got the extendo Echo. It's a little portly, but what makes me anxious about using it is how much of a mess I can make with it in 30 minutes. I go ahead and figure twice as much time for cleanup when I get it out.
    fuelrod, eatonpcat, John D and 3 others like this.
  6. fuelrod
    fuelrod
    Western Maine
    My last 3 chainsaw purchases have been Echo's. The other 7-8 of my older saws are Stihl.
    I'm very happy with my CS620P, a 60 cc class and the sizable price difference has not showed up in quality or performance. :thumbs:
  7. Ohio
    Not Ohio
    I like my Echo PPT 2620. It is kinda chunky. The Stihl pole saws I looked at the shaft looked fragile, they also cost more and are 4mix.I count on my shoulder being sore if I run more than a tank through it.
    You can also buck firewood from a lawn chair. :cool:
    John D, ammoaddict, MikeInMa and 7 others like this.
  8. Eckie
    Eckie
    I have put my hands on the stihls, and was going to get one of the biggest ones...I think 2 of them went to 16 feet. Hadn't decided between those 2.
    I need to go somewhere and put my hands on the echos. I looked at them online earlier...looks like they only come as 12 ft, and you have to buy the 4 ft extension for longer.
  9. Ohio
    Not Ohio
    That’s right on the echos, 12 foot and you have to buy 4 ft extensions. I do not have any extensions. I have made a few cuts with the power head near face height so I was cutting about 18 feet high. Definitely do not recommend it.
    Some other things about the echo. The carb is a walbro barrel carb. If adjustments are going to be made you’ll need a proprietary carb tool. It’s a small d shape. The muffler has a catalyst in it. I opted to remove mine and it improved the performance by a good 20%, it’s choked up stock and makes a lot of heat which is no good.
  10. JimBear
    JimBear
    I have the PPT 2620 & have the 4’ extension. You can reach some stuff but it’s heavy & you can get yourself in trouble also.
    You have to be a bit more careful when thinking about where stuff is going to fall & trying to get the saw out of the way. It’s pretty awkward.
    It’s a real treat when you get the bar pinched about 20’ up…
  11. Woodpusherpro
    Woodpusherpro
    East of Dallas, Texas
    Haha! Nice.
  12. RCBS
    I've used the D handle unit before from a rental. I bought the straight handle knowing that it's sometimes a struggle to make horizontal cuts with the D handle unit due to trigger location.
    eatonpcat, JimBear and Eckie like this.
  13. Eckie
    Eckie
    Interesting
    I was wondering which was the way to go. Thought the D handle might be useful...
    ammoaddict, eatonpcat and RCBS like this.
  14. RCBS
    It does help to better heft the tool. More natural position for straight cutting. I just knew mine would never be used 'by the book' meaning all vertical cutting. They probably frown upon horizontal in the manual somewhere. It comes with a 2 cycle engine that allows use in any direction/orientation...so that's what I'm going to do with it. :thumbs:
  15. Eckie
    Eckie
    I hadn't really thought about it. But I imagine I'll be using it in the 'traditional' pole saw cutting manner... i.e. up. I guess everyone once in a while for something more horizontal, when it's hard to get to with a normal saw...or like in a cedar.
    I will say, years ago I bought a cub cadet 4 stroke weedeater from tractor supply. That was a bad idea. Had problems with it constantly. Fussed at myself for not buying a stihl. Finally took it to a cub cadet dealer in the neighboring county. Lady was like yeaaahhh...even she didn't have anything good to say about them. They had shindawa, and made me a deal on a new one of those. It's ok, but I still fuss at myself sometimes for not getting a stihl. I'm remembering and contemplating that self discussion right now as I ponder the Echo.......
    eatonpcat likes this.
  16. JimBear
    JimBear
    A fella should buy what they are comfortable with & have good dealer with.
    I read good things about the Echo products & was skeptical about buying them but haven’t had any regrets.
    As far as buying the Echo stuff, I have the pole saw & the small 2511t ( 12” bar ) chainsaw , the 2511 probably gets more use than any of the bigger saws.
  17. fuelrod
    fuelrod
    Western Maine
    I just fired up my 30+ year old echo blower. It's probably been several months since last run. 6-7 yanks and it's running.
    This and a similar age weed Wacker that I bought from a neighbor that had a OPE shop.... 2 houses/moves ago is the light bulb that went off when I was deciding to hop off the stihl train for a try something else. I just didn't realize that this echo experiment had started over 30 years ago!:headbang:
    I still have the 044 he sold me "back then" and it's stihl my big saw but I'm getting to not wanting to lug that big old SOB around when a 60 or 50cc (my Echos) will get it done.
  18. Eggshooterist
    Eggshooterist
    Erff
    Same here. 80% of my cutting is with my 2511P. My favorite saw.
    eatonpcat and JimBear like this.
  19. Eckie
    Eckie
    Bumping this thread....wondering if anyone has experience with the echo battery pole saw? As stated earlier, I have the echo battery chainsaw and like it, and have two 5AH batteries that could run the pole saw as well.
    Sounds a bit silly, but since I don't have a pole saw, i dont know how much I would run one if I did have one.... But I have a bunch of limbs along fences and gates that I need to get. Thoughts are if the battery saw would work for what i need, I wouldn't have to worry about gas saw motor issues if I ended up using not-so-frequently. Yes I know there are ways to deal with that...but still...
  20. RCBS
    If you won't have continued use of one, consider renting a unit for a weekend. I did not fire mine once last year, but it will be used this summer again.
    eatonpcat and Eckie like this.
