Another annual job
Discussion in 'The Wood Pile' started by Locust Post, Nov 2, 2024.
  1. Locust Post
    Got the patio shed set up today after spending several hours rustproofing my trucks for winter. I'll move a cord up next. PXL_20241102_205736130.jpg
    RCBS, eatonpcat, g60gti and 16 others like this.
  2. buZZsaw BRAD
    Nice set up. Tis the season. How close to the house are those racks?
  3. Locust Post
    about 10 feet to the walk in door, then about 20 feet to the stove. The racks are just to hold the tin roof frame.
  4. The Wood Wolverine
    What did you use on the trucks? I’ve been using rattle cans of FluidFilm.
  5. Locust Post
    Corrosion X aviation
  6. Locust Post
    Got the patio shed filled this evening
  7. g60gti
    g60gti
    NY West
    Looking good. Nice feeling having all that heat close on hand.
  8. g60gti
    g60gti
    NY West
    I used FF for a number of years, no
    Complaints. Switched over to wool wax mostly because it was cheaper. Bought 5 gallons and the spray gun with wands. Takes about a hour and I’m good to go. 2007 Tacoma and I’ve done it every year since I bought it in 2010. There’s definitely rust but nowhere near what it would look like without.
  9. Locust Post
    I like using the Corrosion X because it not only protects it will neutralize existing rust. I flood all the panels till it is running out the seams. Just my 2 cents.that is the aviation formula I also use the heavy duty formula on the under carriage.
  10. Locust Post
    Continued my annual chores, moved the pressure washer from the unheated shed to the heated garage, have some p!anters to stow away yet before the cold sets in.
