Not until Christmas?
Discussion in 'Modern EPA Stoves and Fireplaces' started by SD Steve, Oct 29, 2024.
  1. SD Steve
    SD Steve
    South Dakota
    So, I need a new piece of vermiculite for my wood stove, I broke it in several places, rough handling.
    But, the one that I need from Drolet will not be available until 15 Dec.
    Thankfully we have been having a really nice fall so far, but by Christmas I should definitely be burning for heat. And with what little heat we have needed I'm already down 10% on my propane tank.
    Is there a place I can get one appropriately sized elsewhere? Or am I just screwed until then?
    Any thoughts?
  2. Bigadbob
    Bigadbob
    Interior B.C.
    Never heard if vermiculite in a stove,, ya all got a photo???
    What is Vermiculite. Vermiculite is a naturally-occurring mineral composed of shiny flakes, resembling mica. When heated to a high temperature, flakes of vermiculite expand as much as 8-30 times their original size.
  3. ReelFaster
    ReelFaster
    S.Jersey
    I was able to use stove cement and patch it up until it was replaced if that's an option. Mine was just broke in two. I've gone through at least two playing Tetris.
    Believe it or not I was able to find a replacement on Amazon. Never fully purchased as Drolet ended up sending me one at no cost, minus shipping.
  4. stoveliker
    stoveliker
    Eastern Long Island
    I have heard there are after-market C-cast baffles. They are less durable but will get you through to December. Not sure where to get them though.
  5. brenndatomu
    You can also order a ceramic insulation board too...often times you can order a piece big enough to make two for the price of one factory baffle
  6. billb3
    I'd call around local stove places and see if they have any vermiculite board or ceramic board in stock. As you've found, as much as it is heat resistant, it's a little tender. They make vermiculite bricks, too, but I've never seen one (I don't think).
  7. wildwest
    Steve, we had a part die on our Drolet pellet stove, don2222 got one for me weeks before that part was "in stock" at Drolet.
  8. Dunmyer mowing llc
    Dunmyer mowing llc
    Amazon has the ceramic board.
    I bought a big piece last year, ran it all season and was fine.
  9. JimBear
    JimBear
    If you can order a baffle that is larger, that vermiculite cuts easily with a cross cut saw. I have had to trim mine both times to get them to fit the width.
    wildwest, ReelFaster and brenndatomu like this.
  10. stoveliker
    stoveliker
    Eastern Long Island
    could a baffle for Osburn stoves fit? (Same mfg)
    Woodmans parts plus sells such baffles
  11. yooperdave
    wildwest, SD Steve and JimBear like this.
  12. SD Steve
    SD Steve
    South Dakota
    Yep sure did!! I called Drolet and the guy on the phone said that C-cast panel is more durable, and available sooner!
    kcgoba, wildwest, Noth and 3 others like this.
  13. SD Steve
    SD Steve
    South Dakota
    I found one from drolet, that guy said it's MORE durable than the original. Hopefully it works out!
    wildwest, Noth, yooperdave and 3 others like this.
  14. yooperdave
    :handshake:
    wildwest and brenndatomu like this.
  15. SD Steve
    SD Steve
    South Dakota
    I still haven't received that panel yet, and it's about to start getting into the teens at night. I called and asked about it. They said they have packaged it, but might not be shipped until Monday. I don't know, I guess I get it when I get it.
    yooperdave, wildwest and brenndatomu like this.
