Homesteading Chicken Coop Build, Chickens, Pond, Garden & Projects
Discussion in 'Hobbies and Interests' started by Well Seasoned, Mar 25, 2018.
  1. wildwest
    Thanks, I'm the same with troubleshooting, but except for the first summer (mites) they've been fine and it was me being a worry wart. That and the dog attack.
  2. wildwest
    Got the coop cleaned and fresh shavings in today. What a relief! Snow due Tues. This will be our 11nth winter here, the latest first snow since we moved in here ~2013
    metalcuttr, HDRock, Biddleman and 7 others like this.
  3. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Is this one of your's?
    T.Jeff Veal and wildwest like this.
  4. Well Seasoned
    Coop winterized here as well- have a new heater to keep the water from freezing, we'll see how it does. 17°F tonight with heavy snow squalls- chickens warm and happy! Been boondocking for a few months, son running the homestead-
  5. wildwest
    I've not seen any but would COOL if it was!
    savemoney and T.Jeff Veal like this.
  6. Biddleman
    Biddleman
    River Hills of Pennsylvania
    What brand of heater are you using?
    I haven't winterized my coop yet. It's only gotten down to the mid 30s a few times so far. I did norice they're starting to roost a little closer to one another.
    metalcuttr, bogieb, wildwest and 4 others like this.
  7. Well Seasoned
    Farm innovators c-250 submersible. I cannot speak if it's quality yet.
  8. wildwest
    :popcorn:
    Doggie was barking tonight while kiddo was jumping on the tramp in the dark, didn't bother as doggie gets the barking zoomies when she jumps and races around the tramp and yard.
    Doggie didn't come in with kiddo but her Halo collar Warner said she was right here. She was in the chicken run! (chickens were locked in their predator proof coop). The chicken wire was pulled in up high in a couple spots, seems a racoon was in there and climbed up. Anyway. we found doggie , and fence repair for the chicken run tomorrow.
    (The weak chicken wire is not dog/predator deterrent but way to keep chickens contained, our dog does not kill chickens thankfully.)
    metalcuttr, JD Guy, sms4life and 3 others like this.
  9. wildwest
    Molting is pretty much done, rooster had new feathers coming in. 1 egg in the last 2 weeks. :eek: One
    metalcuttr, JD Guy, Biddleman and 3 others like this.
  10. wildwest
    I tried to zip tie the chicken run to repair today, bummer, the bulk pack of little zip ties I bought are junk. The little tab thing that catches the ridges broke off in 2/3 of every one I tried and the ones that did not snap off barely gripped the ridges. So, it's temporary but worked for now to keep them contained.
    For sure something went on in there last night. Older heavier broken zip ties on the ground, extra chicken wire on the roof loose, the human door to chicken run is tweaked/bent and hard to unlatch/latch. Chicken wire pulled inwards is one thing but this must have come from dog telling the coon to take a hike. Lock the coop early again tomorrow night and Saturday try again with bigger cheap zip ties and hope they work. I have garbage bag twisties last resort.
    MikeInMa and bogieb like this.
  11. MikeInMa
    I have both of these. I find countless uses for them around the yard. The thinner stuff has a handy wire cutter. The thicker, you need a wire cutter. Make your "twist ties" as long as needed.
    metalcuttr, bogieb, wildwest and 3 others like this.
  12. billb3
    I use that on tomato cages and some other frames in the garden and "things around the yard". It doesn't break down in the sun like plastic does and last for decades, maybe longer. I used to save bread ties but they break down in the weather, too.
    sms4life, metalcuttr, bogieb and 2 others like this.
  13. wildwest
    Thank you, my "garbage bag twisties" are actually a spool like that, but NOT heavy duty. I'll see if I can order some. I have a lot of aquaruim tubing from before, and also marine speaker wire spools. I'll have to knot those though. Just thinking...
    metalcuttr, bogieb and MikeInMa like this.
  14. Biddleman
    Biddleman
    Trying to figure out what's going on with my chickens. Out of 9 hens. Im getting 1 egg every other day. Its the same chicken because she lays green eggs. 4 of the hens are 2 year old, and 2 of those girls are molting, so I know Im not going to get eggs from those 2. The other 2, I have no idea why.
    The 5 others were peeps this past spring and the 1 egg layer is one of them.
    I haven't changed food or offer them more scratch or treats than normal. I looked for mites and lice, nothing there.
    I guess its the shorter days. But the older birds still layed throughout winter last year.
    Weird part is I'll hear the "egg song" and look everywhere and nothing there.
    Chvymn99 and wildwest like this.
  15. wildwest
    I have the exact thing here! Almost every point you made including my older hen's previous laying year round. Their molt is over a few weeks now.
    Biddleman and Chvymn99 like this.
  16. Well Seasoned
    Research your feed, the box stores have been back to manipulating the feed. Also the shorter days could be the cause.
    I've been mixing in wild bird seeds to help mitigate this. Considering going back to the local feed store for the more expensive stuff.
    Also check that the chickens don't have yolk face (eating their eggs)
  17. LCBug
    LCBug
    WI
    The 4 older hens won't lay as many eggs their second season but those eggs should be larger than the first season. It also usually takes longer for them to get back laying after a molt. Your pullets, if not one of the high production breeds, could take up to 7-8 months to start laying. The granddaughter's hens, which are mostly colored egg layers, are taking longer to come into lay than the production hens and they lay fewer eggs. The lack of daylight is the main reason for egg production dropping this time of year. Hens need 14+ hours of light to keep going although I hear a few breeds do better than others through the winter. You can also try upping the protein they get using linseed or fish meal. If you have a feedmill try their mash or see if you can purchase one of the meals to mix in with their regular feed. For the last 15 or so years I've fed a custom mix but the smallest batch the mill will mix is 500 lbs, maybe not feasible for some. The last batch I picked up is the winter ration, extra protein and alfalfa meal for good looking yolks. This is what I feed all the birds, after a month on starter crumbles. Doesn't matter if it's meat birds, turkeys, quail, or laying hens. No soy, no corn, it's what my customers want.
    wildwest, Biddleman and Chvymn99 like this.
  18. Biddleman
    Biddleman
    Great info LCBug. I'll stop in the mill I get my feed. Right now it's Nutrena. I did see they posted that they have a new feed. Don't know specifics.
    I miss them free ranging.
    Chvymn99, LCBug and wildwest like this.
  19. wildwest
    Appreciate your info too! My pullets are just over 8 months now. I figured they should be laying because they are now hanging with the rooster when free ranging and I thought I saw the red ones squat, I'll wait longer. Meanwhile hope to get a different brand food and some wild game feed to see if that helps.
    Chvymn99, LCBug and MikeInMa like this.
  20. wildwest
    WWW finally made it a feed store for different chicken food, it will be given soon after last of Murdoch's brand is gone. Fingers crossed we'll get some eggs again. Bonus, this is just a few blocks from his new shop.
    Bonus #2, they sell pellets for pellet stove for almost $3 less per bag than ACE.
    Bonus #3, there is a small service station with gas pumps next door to the feed shop that is said to take company accounts to the crews can fill up right there at end or beginning of the work day. Cool!
    This is the brand we're ditching
