Osage can you see
Discussion in 'The Wood Pile' started by cezar, Oct 18, 2024.
  1. cezar
    cezar
    KY
    Fellas my MS251 has met its match. This stuff is absolutely brutalizing my saw.
    Biggest Osage I have ever seen. I committed a heinous crime by cutting it up for firewood. Main trunk 16" round, 40 foot long, and straight as an arrow. Unfortunately it's in my way and I don't have a good way to get it out of the forest except in pieces.
    I can barely lift the 16" rounds.
    brenndatomu, JD Guy, thistle and 23 others like this.
  2. metalcuttr
    metalcuttr
    western WA
    Terrible, terrible pun!:picard:Actually physically painful!
  3. Ronaldo
    Ronaldo
    That is a biggun and I’m sure you are wishing for a little bigger saw! Look like you are gettin er done though!
  4. Backwoods Savage
    That saw will still cut it. True it takes a little longer than a bigger saw but let it work.
  5. cezar
    cezar
    KY
    I swapped to a chain with taller rakers and that did it. You really need to take slow nibbles with this stuff.
    This is a little over half the hoard. Called it quits for today. I ended up leaving the bottom 20 feet of the tree for future milling purposes. It's airborne so I have a couple years at least.
    Was an interesting project. The tree was parallel to my trail but then the top half crossed over the desired path and hung up on a maple about 30 feet up. What I did was cut a notch underneath where the tension b/w the top and bottom halves of the Osage met and then backcut the top which caused it to drop. I then took 16" rounds off the bottom and worked my way up slowly. Basically took little bites as the kerf would close up. Kept removing weight from it. Finally I got everything except the top portion:
    You can see here if I just cut the piece on the right then the vertical piece would be at (small) risk of coming back at me. So what I did was cut it 90% to weaken it mostly and then put the winch on it and yanked it to break it. Then from there I yanked the vertical portion until it flopped onto the ground and the rest was a cake walk. A fun and engaging puzzle where if you make the wrong move you die. Definitely at the 80th percentile of my skillset. I've only been using a chainsaw for a couple years and this took me all day to figure out.
    I have a new problem:
    That mark is where my X27 bounced straight off it. It laughed off my 6ton splitter. I can't afford to rent a splitter for this amount. I'm uninterested in attempting with a maul. Might have to noodle it down. IDK.
    These rounds are insane. they're 16" and easily 120 lbs. I can barely lift them.
    I did put the moisture meter on them, basically tried to keep it in a single ring to approximate the correct way of measuring a split and read 17% so these are either mostly or fully seasoned which is awesome.
    MAF143, brenndatomu, thistle and 11 others like this.
  6. Chvymn99
    :D... Welcome to Hedge... :dex:
  7. Locust Post
    That is one wood I have never had the pleasure cutting.
  8. Deererainman
    Deererainman
    Union City Ky
    MY #1 favorite firewood. Great burning firewood and can sit in your firewood stack for years and stay rot free.
  9. Deererainman
    Deererainman
    Union City Ky
    Back in the day, Dad and I worked up a lot of Hedge with McCulloch 10-10's. His big saw was a Mac Super Pro 81. Great score!
  10. buZZsaw BRAD
    Hey metalcuttr he's living on the hedge! :doh:
    Got a good chuckle out of me...of course! :D:emb:
    Nice stuff there cezar. My holy grail score. And I love the thread title!:salute:
  11. buZZsaw BRAD
    cezar try hitting it in the big center check (crack) and it should split easier.[​IMG]
  12. Dunmyer mowing llc
    Dunmyer mowing llc
    Yep trying to split Osage was what finally convinced me to buy a splitter. The big brother maul version of the x27 will do it. But Osage makes you earn it
  13. Moparguy
    Moparguy
    TN
    That is a GREAT score! I've never really had trouble cutting it. The ones around here aren't what I would call "straight". They're straight for a little while then they branch up, outward, and down almost like a monster arching and curling it's arms and fingers scarily at you.
    MAF143, brenndatomu, thistle and 10 others like this.
  14. Cash Larue
    Cash Larue
    Pine, CO
    Nice grab!! I have hoarded some of that stuff in Eastern Colorado. But otherwise, very rare around here. Good stuff.
  15. Chvymn99
    True If its fresh and alive... :D ... But it looks like its been dead for a bit, and then it can be very hard on chains... :doh:
  16. T.Jeff Veal
    Wow, great score. I've never seen any around here, I don't think...
    Chvymn99 gave us a few pieces at a GTG one time, then a friend in Ohio gave us some, made about a drum and half when split... 0506220933.jpg
    cezar, brenndatomu, thistle and 11 others like this.
  17. Hinerman
    Hinerman
    NE Oklahoma
    Normally, it is easy to cut. But, as you say, if it has been dead, it becomes very hard. I have had semi-chisel bounce off, and not bite, at all; like it was just scratching the wood.
  18. The Wood Wolverine
    If you can find any, recurve bow makers seek Osage out to make those. Might get good money for prime pieces.
    Great score. Never had any.
  19. metalcuttr
    metalcuttr
    western WA
    Et tu, Brute?:hair:
  20. cezar
    cezar
    KY
    Went out this morning to cut some more osage. In the first cut my saw completely fell apart halfway through. I have no clue what happened but I can only assume I forgot to torque the bar nut at some point. Put it back together and started it up and it seems fine. I took that as a signal from the universe to call it quits and drove into town for brunch.
    Been thinking about splitting this stuff. I'm getting a alaska mill from Farmertec at christmas. Would that work for noodling down do you think?
    Other than that I think I really want one of those tractor splitters that use the hydraulic remotes. I can't swing the 1k they cost new but I saw one on Cragslist halfway across the country for $250 which is a great price. Have to keep my eyes peeled for one closer to my region.
