Forgot To Mix.....hurrdurr
Discussion in 'Chainsaws and Power Equipment' started by reckless, Sep 24, 2014.
Thread Status:
Not open for further replies.
  1. reckless
    reckless
    Well went and filled up my 2 gal mix tank and forgot to add 2 cycle to it, it wasn't completely empty when I filled it so it had the color of mixed gas but when I ran it through the leaf blower (before I realized) it ran for 20 min and shut down. I have since emptied it and filled it with the proper mixture 50:1 but was wondering how much damage I did running it lean/barely any oil.
    Thanks!
  2. Cut4fun
    Cut4fun
    OHIO Redneck
    pull muffler and it will tell you all you want to know.
  3. Moparmyway
    Moparmyway
    New York
    You will need to pull the muffler and have a look inside at the piston, rings and cylinder. Post up a few pictures if you want and we will steer you straight
    $ooline likes this.
  4. HDRock
    Oh shoot :eek:
    Are you trying to live up to your name ? ;):D
  5. clemsonfor
    Pull muffler and look at the cylinder then pull rope slowly and look at the rings and piston skirt as it goes past the exhaust. 50:1 is already pretty lean so hope there was enough residual and you didnt put to much wear on it or scratch it all up:(:mad::doh::headbang:
  6. reckless
    reckless
    Always!! I got it from HD last month so worst case I go exchange it.
  7. Cut4fun
    Cut4fun
    OHIO Redneck
    o_O:zip::eek:
  8. redneckdan
    redneckdan
    Northern Minnesota
    Speaking of mix, what are yall running for mix these days? I know the husky premix is 50:1. I run 25:1 in my mac 10-10. Just wondering where I should be running my 576xp and 455.
  9. jharkin
    jharkin
    Ive seen people score the cylinder and blow the motor running just one tank of straight gas by accident. Hope you didnt but I have a bad feeling you are gonna be buying a new piston and jug :(
    Scotty Overkill likes this.
  10. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    For longest life run 32:1!
  11. clemsonfor
    What is hurrdurr?
  12. basod
    basod
    Mount Cheaha AL
    Don't feel bad, I had a similar brain fart years back with a 2gallon can, only put 1 bottle of oil in it.
    The Pullon farmhand, and a weedeater brand blower both suffered the same fate
  13. HDRock
    that's like a titty twister :D
  14. clemsonfor
    :doh:
  15. reckless
    reckless
    seems to be running perfectly fine at the moment with no power loss.... how would I know exactly? Im not taking it apart as I can still return it.
    This:doh:with:headbang:and some :picard:
    concretegrazer likes this.
  16. clemsonfor
    Compression test. Peeking through plug holewill tell a little.
  17. jetjr
    jetjr
    Pa/Md line
    I know of (ok I was there:emb:) a guy that powered a chainsaw with diesel for a little while. That's what happens when your employer was to cheap to get a yellow can for diesel. Ran ok but smoked like a some beech.
  18. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Why would you try to return it? This is not a warranty claim, but simply operator error. Don't try to stick your self created problem on the manufacturer or dealer.
    Oliver1655, Joe, cutforfun and 12 others like this.
  19. jetjr
    jetjr
    Pa/Md line
    I agree with @Guido Salvage on this one. It was a snafu on your part I know a lot of people would return. Ultimately it's your call. I know HD is good about returning stuff has I had to return a mower one time with 3 hours on it. That was not my fault though the Trans stopped working. They did try to say I needed to contact a service rep at first.
  20. $ooline
    $ooline
    WI
    Gotta agree with Guido.
Thread Status:
