Stoves from Tractor Supply???
Discussion in 'Modern EPA Stoves and Fireplaces' started by shack, Oct 16, 2024.
  1. shack
    shack
    Upstate NY
    A buddy is looking into getting a stove. Came to me for advice...but I burn a Fisher Baby Bear and love it...I am very out of date on stoves.
    He is looking to not spend a lot of money and hasn't found anything in the Secondary Market. He's been looking at TSC stoves....they seem to have names like Grand Teton, Cleveland Iron Works, US Stove and Pleasant Hearth. All of these seem to be in the $500 to $900 range.
    Are these stoves worth buying? I have heard mixed reviews about them.
    I know he's looking for a Non Cat stove, glass in the door to see the fire, simple to use stove that is in the $700-$900 range. To heat about 1,200-1,400 sq ft.
    No idea what to tell him. TSC has some good prices...but we all know a good price for something that doesn't work is no bargin.
    The used stoves on Market Place and CL have been okay at best, kind of used hard, and people want top dollar.
    He wants to stick with something newer or just plain new and budget is an issue.
    Yeah, I know wrong time of the year to be buying a stove...but gotta start somewhere.
    Thanks for any advice.
    There May OR May Not be free steaks for folks that respond to this post...:salute:
  2. Eric VW
    I like free steaks…:D
    I have an Ashley WonderWood, has secondary air, but no glass. Works pretty ok.
    Aside from buying a TSC stove (they’re all ok), the 2 questions you’ll be faced with here are 1) does your buddy have dry wood, 2) what is the chimney setup?
  3. shack
    shack
    Upstate NY
    Thanks for the TSC stoves 'works pretty ok'.
    He's ready with enough wood to get him through the coldest part of winter and he's putting the 'new' stove where there was one, just needs some stove pipe...he did have the chimney cleaned and inspected...so he's good to go...just needs to find the stove. I know a lot of people need the stove, hearth, chimney, wood and think it's going to happen next week....wood burnin' takes a little planning and he's further ahead than most of the bears in the woods.
  4. Eric VW
    By that I meant they’re no BK or Woodstock… any stove will work provided the givens about dry wood and chimney/draft- thing I would look for is that the fire box is big enough for splits on hand- recutting down to a length that fits gets old quick unless done in bulk.
    As for build quality, I see no glaring issues. Check the door gasket before start up, adjust if necessary, do the burn in fires to cure the paint, then off to the races!
    :yes:
  5. Todd
    Todd
    NW WIS
    I’d pass on those stoves and look into the Drolet line. I think they are the best bang for you buck stove out there. Made in Canada not China!
  6. wildwest
    I've not seen a lot of love for US Stove on this forum.
  7. Eric VW
    I always forget they’re quite affordable.
    :handshake:
  8. shack
    shack
    Upstate NY
    Personally, I am looking for a Jotul Black Bear with a glass door...just been surprised at the prices $$$
    metalcuttr, wildwest, JimBear and 4 others like this.
  9. brenndatomu
    US stove has had some "ok" stuff, nothing great...but also some HUGE turds! I would't go out of my way for any of them...and make sure that he doesn't buy a fixed rate stove...some of those cheap ones have NO air control...thats how they passed the EPA test, burn it fast n hot (they cheaped out in RnD basically)
    I second the Drolet line...decent quality n price...also good Canadian factory support (at least built on the same continent!) whereas the china made stoves usually dont!
    I like these guys...basically the factory store for Drolet and brother/sister brands (which includes Englander now too)
    MFP - The Online Stove and Fireplace Store
  10. Backwoods Savage
    I would advise staying away from US Stove. Most of what TSC sells are bottom of the line unless they have taken on some new ones.
    Drolet and Englander might be his Best Buy for lower cost.
  11. stoveliker
    stoveliker
    Eastern Long Island
    If he does get a US stove one after all (life can force people to make choices like that), make sure he doesn't push the stove hard, as that'll surely decrease its lifetime a lot.
    So get one that is big enough (or not so small that it needs to be pushed.)
    metalcuttr, wildwest, shack and 4 others like this.
  12. Dunmyer mowing llc
    Dunmyer mowing llc
    Stay away from us stove/ vogelsang
    I bought the 3000sqft model for 1500$
    This is a secondary tube stove.
    In factory form these stoves have so much unmetered air that even small fires would run away.
    Even with a damper in my stovepipe I literally was starting to melt the stove top
    My temp gun maxes out at 999 and gun was pegged.
    Long story short I have deleted/ welded/ plugged all secondary burn functions so now I have a smoke dragon with a glass door.
    Stoves are a buy once cry once purchase in my opinion.
    My next stove will be a high end brand
    metalcuttr, wildwest, shack and 5 others like this.
  13. stoveliker
    stoveliker
    Eastern Long Island
    A lot depends on the height of the flue as well.
    golf66, metalcuttr, wildwest and 3 others like this.
  14. brenndatomu
    This Century is on sale, and a lot of stove for the money...I forgot to mention before, they have free shipping on orders over $100 too.
    CB00021
  15. theburtman
    theburtman
    We have a Century bought in 2004 for $600. Replaced the bricks once and the door glass (which was totally my fault) once. We wear shorts and tshirts inside our 1300 sq ft house all winter. We use roughly 2 cords of wood and 25 gallons of HHO.
  16. brenndatomu
    Which model do you have?
  17. theburtman
    theburtman
    S274E
    Not a current model. Supposed to heat up to 1500 sq ft. Takes up to 22 inch logs. It came from a local dealer.
    metalcuttr, wildwest, shack and 3 others like this.
  18. Ward Hoarder
    Ward Hoarder
    West Virginia
    Wonder Wood from TSC for the garage held up good. Don't be afraid of second hand. Recently acquired a Fisher Momma Bear for Free. I don't think it was ever used. Had to move it myself, what a job. Stove was dirty and had a mouse nest in it, but wasn't occupied.
  19. JimBear
    JimBear
    I have had a Century FW3000 for 4 -5 years now heating a 1300 sq. ft home. I replaced the firebricks this year & have had to replace the vermiculite baffle twice. The broken baffle is from being to rammy loading the stove.
    My dealings with customer service has been great.
  20. theburtman
    theburtman
    MY baffle is not removable. It has a couple dents in it, but the stove still functions fine.
    Horkn, MikeInMa, Chvymn99 and 4 others like this.
