Thoughts on Drolet Deco II for an off-grid cabin
Discussion in 'Modern EPA Stoves and Fireplaces' started by TnMan, Sep 24, 2024.
Tags:
  1. TnMan
    TnMan
    Middle Tennessee
    We're building a smaller (12'x24' with a 12' loft) barn style cabin on our hunting property, and I'm trying to decide on what stove to put in it. It will not be insulated, it will have 5 windows (4 on ground floor and 1 for the loft), a residential door, and will have a metal roof.
    I know it not being insulated will make things less ideal, but I think I've settled on the Drolet Deco II and wanted ya'lls thoughts on it. Mainly the Deco II because it's a smaller east-west loader and in my experience the East-West loads do better for slower, longer burns and I'm worried a N/S loader will burn too fast and get too hot for that small of a space. Also wondering if a Drolet is too "nice" of a stove for an off-grid cabin and if I should just get a cheaper US Stove/Grand Teton stove from TSC and call it a day. We'll only be there on the weekends during hunting season (Nov - end of Jan) and maybe for 3-4 straight days during the holidays. I've got PLENTY of nice dry wood ranging from oak/hickory/cherry to tulip poplar and pine.
  2. brenndatomu
    With the high ceiling in the there that stove should be fine.
    Where you buying, local?
    If not, check out myfireplaceproducts.com it's basically the drolet factory outlet store.
    Chvymn99, wildwest, MikeInMa and 2 others like this.
  3. TnMan
    TnMan
    Middle Tennessee
    I'll check that site out! Home Depot will sometimes get Drolet stoves but they're hit or miss.
  4. Backwoods Savage
    I have no love for a US stove. I also have no experience with Drolet but know a few that have them and like them very well.
    Chvymn99, wildwest, Ohio and 2 others like this.
  5. brenndatomu
    X2, USSC is chicom junk (ironically), spend an extra couple hundred and get something made to last more than a couple years...better functionally too...plus they are made by our friends up north, and drolet will actually stand behind their warranty, I've personally seen it. I've had a drolet 1400i in the living room FP for years now...don't use it a ton, but it works great when it's called on.
  6. billb3
    My TN19 N/S burner goes overnite and it certainly doesn't burn "too hot". Drolet has a couple of smaller stoves but they may not burn long enough for your use.
    I'd rather have a stove made on the continent than from the wetsren pacific. That said, I had good luck with a Taiwan stove that never got good grades. I was lucky and got a good one although at 40 years old it had started to fall apart so I recycled it this Summer.
    That Deco II ;looks like a good choice and note that Drolet has sales on some models every now and then.
    TnMan, wildwest and brenndatomu like this.
  7. wildwest
    Happy Belated Birthday Bill :)
    billb3 likes this.
  8. Canadian border VT
    Replied because this needs to be read again
  9. ReelFaster
    ReelFaster
    S.Jersey
    No experience on the Drolet Deco II, but I do have a Drolet 1800i for several years now. Bought and began using winter of 2018/19. It's been very good to me so far and the customer service has been very good. I believe they've sent me two baffles early on because I was a noob and cracked it trying to play Tetris. I've also reached out to them with various questions especially early on and they've always responded and been helpful. Good luck with your decision!
  10. Todd
    Todd
    NW WIS
    Not sure I agree that E/W loaders have longer burn times. With a N/S loader you can fit more firewood in without worrying about logs rolling down into the glass and fit them tighter. You also get a better front to back cigar type burn with a N/S loader. A shallow E/W firebox seems to engulf the whole load at once especially in a non cat stove. I would also consider the Drolet Spark II.
    TnMan, blacktail, Chvymn99 and 2 others like this.
  11. brenndatomu
    Agreed...a square stove that can be loaded N/S is preferable IMO
    TnMan, ReelFaster and Todd like this.
  12. CutSplitStack
    CutSplitStack
    Just installed this in my cabin, so far I am a big fan. Good looking unit. Heats well and burns slow with the controls on it, you won't regret it. 20240919_103432.jpg
    moresnow, TnMan and brenndatomu like this.
  13. TnMan
    TnMan
    Middle Tennessee
    Thanks!! What a coincidence. Looks great, how was the install? Pretty smooth?
    brenndatomu likes this.
  14. CutSplitStack
    CutSplitStack
    Pretty smooth, I had a different stove in there so it was just redoing the pipe. Old stove didn't draft well, but this one is great. I did do 2 45 degree elbows up top instead of a 90 going into the wall, the instructions said the stove can be picky if it's not a straight up vent scenario. Also as a heads up, the first few fires are a little rough bc the coating cooks off the exterior. But if you keep it in the proper temp range it's minimal. Gets crazy if you let it get to hot though. You will love this stove!
    TnMan likes this.
  15. brenndatomu
    Good call on the two 45's.
    Best time to cure the paint is a cool fall day where you can run the stove and have the windows open to air things out.
