Can anyone help me out? Need hinges
Discussion in 'Everything Else (off topic)' started by BCB, Sep 4, 2024.
  1. BCB
    BCB
    USA
    IMG_3578.jpeg Well my trailer ramp hinges need to be replaced for the 3rd time in 5 years. The ones I’ve been using are the biggest that the local hardware store offers. Before I do anything I wanted to see if any of the forums blacksmiths or metal guys would be interested in making me a set of the last hinges I’ll ever need lol.
    PM me if you’re up for the task and I’ll get you measurements and you can let me know the price. I’m in the middle of a job right now and don’t have a tape measure on me.
  2. BCB
    BCB
    USA
  3. brenndatomu
    I'd make that out of 1/2" black pipe and some 1/2" round stock.
    Cut the pipe into 5 sections and weld 3 to one side (probably the gate) and 2 to the other (probably the trailer side) (weld them to some flat bar, angle, channel, whatever works best to attach to the trailer and gate) leaving a 1/8"-1/4" gap between each section.
    Then use the round stock to act as the hinge pin.
    Make sense?
  4. Scotty Overkill
    That's what I was thinking also. I'll try and draw up a crude diagram
  5. ironpony
    ironpony
    Mid Ohio
    Wrong part for the job do as brenndatomu said
  6. lukem
    I don't think this is a custom job. You can find heavy duty barrel hinges pretty easily. Check an agricultural type store (farm fleet, tractor supply, rural king, etc).
    FTG-05, wildwest, eatonpcat and 5 others like this.
  7. brenndatomu
  8. buzz-saw
    buzz-saw
    Ct.
    McMaster Carr or MSC industrial
    wildwest, JimBear, eatonpcat and 3 others like this.
  9. Screwloose
    I'd suggest you pretty much follow brenndatomu's plan. Well proven and cost effective.
    FTG-05, wildwest, RCBS and 4 others like this.
  10. RCBS
    Mine is similar but only with two attachment points. The stud on one side needs to be shorter if you plan to remove & reinstall on your own. Wish I could get a pic. Rudimentary and effective. Had a TSC trailer for a bit and the gate was not removable which is a pain in certain situations.
  11. BCB
    BCB
    USA
    Thanks for the responses. I'll check out your suggestions.
  12. RCBS
    I actually remembered to snap a pic of mine since I was using it Saturday. Very rudimentary. Works great.
    FTG-05, BCB, Woodwidow and 3 others like this.
  13. BCB
    BCB
    USA
    Thanks. I picked up a flux welder from HF last week and will be learning how to weld. The trailer gate hinge will be my first project.
  14. RCBS
    A skill that no one ever shared with me. I do know a couple guys who are good at it though.
    FTG-05, Chvymn99, eatonpcat and 2 others like this.
  15. brenndatomu
    Anyone can learn it...some people are naturals though...
    FTG-05, stuckinthemuck, RCBS and 2 others like this.
  16. RCBS
    Have never laid the first bead. I have read this cover to cover though.
