Glass gasket question
Discussion in 'Modern EPA Stoves and Fireplaces' started by creek chub, Aug 28, 2024.
  1. creek chub
    creek chub
    Va
    Wood insert glass gasket question
    I looked at a used regency wood insert last night. I’m thinking about buying but have a question.
    The glass gasket needs to be replaced, not a big deal. It looked odd how it is installed now though. The glass sits in the door frame, then the gasket and then a retaining rod. Wouldn’t the glass gasket be better in the frame under the glass?
    I might be overthinking it
    Thanks
    MikeInMa likes this.
  2. brenndatomu
    The glass is touching the metal of the door directly? If so that doesn't sound right
    creek chub and theburtman like this.
  3. Brad M
    Brad M
    Pleasant Hope MO
    Doesn’t sound right to me either. Maybe it was replaced by someone in the past and the got it wrong?
  4. theburtman
    theburtman
    When I replaced the glass in my Century stove, it came with the gasket wrapped around the edge of the glass. I put the glass in, secured it, and lit a fire. The material was compressed and expanded when heated. I hope this makes sense and helps.
    creek chub likes this.
