Random pictures that you took
Discussion in 'Everything Else (off topic)' started by Czed, May 8, 2022.
  1. brenndatomu
    The diesel engines are the smokers in the group...some run alcohol, no smoke
  2. Eggshooterist
    Eggshooterist
    Erff
    We just got back. Next year it is running 14-16th. Theres a nice enough KOA campground 18 miles away near Perrysburg.
  3. Eggshooterist
    Eggshooterist
    Erff
    Yep. That GALOT tractor in the one vid is a superstock unlimited. They convert the diesel engines to burn alcohol.
  4. Eggshooterist
    Eggshooterist
    Erff
    I don't know about the pullers you referred to but the diesel tractors produce a lot of smoke under full power. Some upwards of 4000 hp.
  5. T.Jeff Veal
    Looking at weight ticket, I thought it took 6 minutes...lol...
  6. Ohio
    Not Ohio
  7. yooperdave
  8. Ohio
    Not Ohio
  9. JimBear
    JimBear
    I guess speed reading isn’t my thing, I just read it as loading.
    Here are some pics anyway.
    View from the side door up top, the center trap was open & the outside was open but the 2 middle traps wouldn’t open. I got them opened up after a I got the sweep auger going.
    It’s a 36’ bin, 18’ from wall to center trap.
    This rubber wheel it what drives the auger around the bin. Basically it just spins keeping the auger pushed into the corn pile.
    The sweep is powered off the outside motor on for the horizontal auger under the bin, there is a transfer box in the center trap that sends power to the sweep. If all that gibberish makes sense.
  10. JimBear
    JimBear
    Some bin floors are basically smooth no raised lips.
    The bin I am cleaning out now has the slightly raised lips/ridges & doesn’t sweep well with a broom unless you are going with the “grain” of the ridges
    The bin right next to it has a smoother floor, they are much easier to sweep out. IMG_0454.jpeg
  11. T.Jeff Veal
    Makes sense to me. I helped my cuzn farm in the 80's. He had 4 bins, been inside cleaning them out many times.
  12. spotted owl
    spotted owl
    PNW
  13. spotted owl
    spotted owl
    PNW
  14. spotted owl
    spotted owl
    PNW
  15. Ohio
    Not Ohio
  16. spotted owl
    spotted owl
    PNW
  17. Eric Wanderweg
  18. spotted owl
    spotted owl
    PNW
  19. Bigadbob
    Bigadbob
    Interior B.C.
    Rock that i found while at work placing an anchor. Was in the back country.
    I added the dots
  20. Eric VW
    What in tarnations?!!!
    I like it a lot!
