Chain repair ~ the lesser of two evils
Discussion in 'Chainsaws and Power Equipment' started by Eric Wanderweg, Aug 12, 2024.
  1. Eric Wanderweg
    A coworker friend found this old chain in his garage and gave it to me. It’s a 0.375 x 0.058 x 72DL (20”) which I happen to have a couple bars for. Most of my bars/chains are 0.050” gauge otherwise. Anyway, on one tooth the raker got sheared clear off. To rectify the issue my options are:
    A) grind the rest of the tooth off and run it
    B) patch in a couple drive links that are 0.050” gauge and run it
    C) sharpen the tooth without a raker at all and see what happens :picard:
    What would the experts here do?
    buZZsaw BRAD and MikeInMa like this.
  2. JimBear
    JimBear
    I’d just grind/cut that tooth off.
  3. RCBS
    Sharpen it up and run it. I bet it works just fine. Or as Jim said, just remove it completely.
  4. buzz-saw
    buzz-saw
    Ct.
    x3 , grind it off and run it. Willing to bet you don't notice a difference.
    They sell them with half the cutters so just consider it a hybrid.
  5. buZZsaw BRAD
    Grind off all the rakers, sharpen, put it on your 029 and hold on for dear life! :doh:
    A. I would grind off the tooth. If the chain still cuts funky its trash. I don't recall if I've ever lost a raker. Lost plenty of teeth when they get to nub size.
    MikeInMa, RCBS and Eric Wanderweg like this.
  6. Eric Wanderweg
    Thanks for the input y'all.
    Prior to checking out the forum this morning I did end up patching in a fresh tooth with two 0.050” drive links. Being a freebee I figure this will be used as a junk work chain anyway. With only 2 links being 0.008” narrower I don’t think it will make much difference. For what it’s worth IIRC one of my 0.063 x 0.325 chains is missing a tooth and it doesn’t track weird or act noticeably different.
    buZZsaw BRAD and buzz-saw like this.
  7. eatonpcat
    Meet buZZsaw BRAD
  8. buZZsaw BRAD
    eatonpcat likes this.
