Hand Splitting Black Locust?
Discussion in 'The Wood Pile' started by WESF, Jul 29, 2024.
  1. WESF
    WESF
    MN
    I've never cut black locust before, but a yard tree is on offer locally.
    I only split by hand, and I'm fixated on those knots. How's locust go with a maul?
  2. Eric Wanderweg
    IME it's not bad at all. Not as easy as straight grained oak, but better than sugar maple.
  3. WESF
    WESF
    MN
    Funny you mention maple, Eric Wanderweg . I also find maple is often tougher than expected to split. Even red maple. It's almost like it doesn't have enough grain to split well.
  4. Eric Wanderweg
    Yeah maple is a workout more often than not, especially with the crotches and knots. Black locust wood is pretty brittle so even on the crotch sections, hitting it in the right place usually works.
  5. 0rion
    0rion
    It would be worth the work just because of the quality of wood it is.
  6. Deererainman
    Deererainman
    Union City Ky
    buZZsaw BRAD will have a conniption when he sees that, good thing your in MN. :rofl: :lol:
  7. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Get it.
  8. theburtman
    theburtman
    I hand split 6 pickup loads of Black Locust without much difficulty.
  9. Rickyblazin
    Rickyblazin
    Pottstown PA
    Thats an awesome score
  10. buZZsaw BRAD
    GO GET IT! GO GET IT, GO GET IT! Call them immediately WESF
    Those big chunks will kinda fall apart as you section them up. Some of the gnarlier chunks will give you a bit of trouble but when I hand split I never had any problems with BL. Common to see decay and ant damage too.
    IME/IMO let the bark on sections sit for several months until the bark loosens. The bark is 2" thick on big stuff like that. WARNING!!! It's very slimy and smells like decaying flesh. Most putrid wood smell IME. Even if rounds sit they still should split easily.
    Here's the biggest BL I ever scored from last Summer.
    Biggest BL I've Ever Cut.
  11. buZZsaw BRAD
    Have you tried this trick? If you don't split it fresh cut the ends of the rounds will check and its a LOT harder to crack them. Store them with one end touching the ground so it stays damp. Split from the damp end and it pops easily. Learned this by accident years back.
  12. WESF
    WESF
    MN
    Heck of a sales job there. You too can make your neighbors wonder if there's a rotting corpse in your woodyard! Act fast and call now - operators are standing by!
    o_O
  13. T.Jeff Veal
    That would be a great score, get it as fast as you can
  14. Backwoods Savage
    I would probably turn that down.
    eatonpcat, jrider, ThomH123 and 2 others like this.
  15. lukem
    You probably aren't going to split that one piece by hand unless you had some wedges. I'd just cut the knotty section out and get rid of it. The rest looks fine to me.
  16. jo191145
    As Brad said, most of that will fall apart. That knotty section chop up with a chainsaw. It’s good stuff. Worth the effort.
    For our Ct folk there’s a nice size log in Unionville right now ;)
    Ahem ahem Eric :)
  17. WESF
    WESF
    MN
    Okay, okay, I'm at least intrigued by this mysterious wood. I'll give it a shot.
  18. Scotty Overkill
    The only BL I've ever had any struggle with is the gnarly stumps.....the knots may give you a "little" fuss but generally speaking BL is easy to split and well-worth any slight struggles it gives you in thr end.....
  19. buZZsaw BRAD
    Eric's hibernating from hoarding in the heat. If I was closer maybe.
    Dunno of he would take BL as he's been on an dead oak kick as of the last year.:loco: :crazy:
    MikeInMa, T.Jeff Veal and theburtman like this.
  20. buZZsaw BRAD
    Thats the FHC spirit right there. Shouldn't be a problem sectioning it up with a maul.
    MikeInMa, Deererainman, WESF and 2 others like this.
