Refinishing a tiger maple table top
Discussion in 'Hobbies and Interests' started by The Wood Wolverine, Jul 18, 2024.
  1. The Wood Wolverine
    Made this hall table probably 20 years ago. Curly maple top w/ a walnut base. Wife sat plants on it and they leaked, unnoticed, for a while. :headbang:
    Started with 100 grit sandpaper, worked through to 150. Removed 90% of the damage. There was some deep discoloration I didn’t feel like hogging out. You can see the lighter spots. Old finish wanted to clog the paper and was a pita.
    At this point I applied the first round of honey amber aniline dye.
    Then sanded again with 150.
    Aniline dye is a water base “stain”. Just wipe on w/ a lint free rag. Next couple layers I put it on “thick”, then sanded w/ 220. What this does is, allows the areas of curly grain that are oriented in a way to easily suck up dye, to do that. Then the areas that are not, the sanding removes the surface dye. Repeated application makes the curly figure stand out more because the dye penetrated deeper in the differently oriented grain. o_O:wacky: Hope that made sense.
    IMG_0530.jpeg IMG_0531.jpeg IMG_0532.jpeg IMG_0533.jpeg IMG_0534.jpeg IMG_0535.jpeg IMG_0536.jpeg
    Skier76, Chaz, metalcuttr and 14 others like this.
  2. The Wood Wolverine
    Too many pics to keep situated in one post. Final sanding.
    Heavy application of last coat.
    Here shows air drying.
    Completely dry.
    Then I used 000 steel wool.
    Moved to basement for finish coats.
    Poured copious amounts of oil on and rubbed it in w/ a cloth till it quit absorbing.
    Then buffed excess. Directions say 24hrs between coats. I’ll probably do 3, then wax.
    Skier76, Chaz, 0rion and 15 others like this.
  3. eatonpcat
    Looks great Jason, Nice work!
    I see Roscoe was helping!
  4. The Wood Wolverine
    Always. You can see ears up, he’s guarding/keeping me safe. :cool: Must be a bird where he’s looking. Nothing is safe in the yard except people. There’s a couple rabbits he chases on the regular. Usually 2 laps around the wood pile every time he is let out.
  5. Woodwidow
    Wow! Nice restoration job. Saucers under any plant pots in the future? Or not plant pots ever!
    Chaz, metalcuttr, eatonpcat and 4 others like this.
  6. The Wood Wolverine
    Thanks. We’ve moved it from the dining room window to our living room. It now holds 4 crates full of vinyl records. I don’t think it will be permanent however because we plan a dining & living rooms remodel as soon as I get back to work. I’ll more than likely build a rack to store them when that happens. I promise not another plant will leak on it, ever. :picard:
  7. Dok440
    Dok440
    NorCal
    The table top looks great! Love that pattern. Oiled finish is my favorite.
  8. buzz-saw
    buzz-saw
    Ct.
    Well, that's an improvement.
    Looks gooder !
  9. The Wood Wolverine
    Second coat of oil went on this morning. Let it sit outside all day and it set up nicely. Just got done buffing the second coat of wax with 0000 steel wool to get the luster I desired. I’m calling it done.
    I liked it better with natural color maple. The finish I used back then went hard in the can and is no longer available. It was a tung oil varnish.
    I always loved working with walnut. This leg was 1/4 sawn and you can see rays. Love it.
    Skier76, Chaz, metalcuttr and 8 others like this.
  10. Buttermilk
    Buttermilk
    Central AR
    Looks really good. Finely figured lumber
    Chaz, Eric VW, metalcuttr and 4 others like this.
  11. 41FanForLife
    41FanForLife
    Beautiful table Jason. That's some amazing lumber you used. Great job.
    Chaz, Eric VW, metalcuttr and 3 others like this.
  12. brenndatomu
    Going from the pictures, I love the finish you have on it now, very nice!
    Chaz, Eric VW, metalcuttr and 2 others like this.
  13. yooperdave
    Fantastic! Good job and you really got the grain to pop!
    :handshake:
  14. metalcuttr
    metalcuttr
    western WA
    That top is stunning! Excellent work!
    Chaz, The Wood Wolverine and Eric VW like this.
  15. The Wood Wolverine
    Thanks Russ.
    metalcuttr and Chaz like this.
  16. 0rion
    0rion
    It's one of those things where the outcome justifies the hours of labor. If you would've cut corners on any of it you wouldn't have ended up with that final product. I appreciate that and it's a beautiful table because of your hard work and only because of your hard work.
