Possible 044 slant fin
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, Jun 30, 2024.
  1. T.Jeff Veal
    Found a possible 044 slant on FBM for $300, wondering if it's worth it?
    John D and Eric Wanderweg like this.
  2. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Pull the muffler and see what the piston looks like.
    Love mine and it's a steal for 300 if in good shape.
  3. The Wood Wolverine
    I’d say depends on condition. Have any pics to share? As Ron said, view of that piston through the exhaust port is a gold standard (for me) to help judge worth.
  4. huskihl
    huskihl
    If it operates as it should and isn’t cracked/busted up or beat up it’s worth about $500
  5. Chud
    Chud
    Have you bought it yet?
  6. T.Jeff Veal
    It sold already.
    But here are the pics... 20240630_174858.jpg 20240630_174908.jpg 20240630_174952.jpg 20240630_174916.jpg
    Really didn't have the spare $$ right now
  7. buZZsaw BRAD
    Can someone educate me on the slant fin 044? First I've heard of it.
  8. buZZsaw BRAD
    :heidi: Ya ALWAYS have to have a stash of cash in case a deal pops up.
  9. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Yep, never heard of that term. Curious, apparently makes it more desirable than a regular 044?
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Slant fin= (usually) Early model 1128 with a 10mm wrist pin crank. Good numbers for a stock cylinder, per reports.
    They were strong runners. I’ve been into two of them and maybe feel a slight difference between 440s. I don’t time saws or do porting, though. I just cut wood.
  11. huskihl
    huskihl
    Most 044 had a slant fin cylinder from what I can see. Out of (10) carcasses that I picked up, 5 were 10MM wrist pin, 5 were 12MM wrist pin, only 1 of which had the straight fin cylinder on it. The other (9) 10MM and 12MM had the same Mahle cylinder. The very early model 10MM had a Kolbenschmidt cylinder on it that is said to have had better and more aggressive timing numbers. But the 10MM and 12MM Mahle slant fin cylinders are identical inside
  12. buZZsaw BRAD
    So there's no way to tell just by looking at the saw?
  13. huskihl
    huskihl
    You can tell if it has a 10 or 12mm wrist pin by looking at the saw. All 10mm had slant fin cylinders. Some/most 12mm had them. You’d have to remove the top cover to know on a 12MM which cylinder it had
  14. Chud
    Chud
    Was the 044 badge any indication of age. I also notice a difference in air filter cover between mine and the one Jeff’s picture. Mine has a metal badge and the one in the pic is plastic like the 440’s. I also believe mine has the ks cylinder which makes it ultra valuable. :makeitrain"
  15. huskihl
    huskihl
    I don’t remember the exact number, but before serial number starting in 12938 is 10MM. There’s also a 90° notch between the oil cap and the muffler on the magnesium casting that designates 10 MM, as opposed to the side of the case being angled which indicates 12 MM
  16. buZZsaw BRAD
    It'd be interesting to see side by side pics as IDers.
    Also how much more is a slant fin worth vs a "normal" 044? Im not wanting any version of an 044/440/441 for my arsenal but if I can find a deal on a slant fin, why not?
  17. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Outside of the saw nerd community? Maybe just a little more.
    Many loggers and arborists around here have completely moved on from that era of saw.
  18. huskihl
    huskihl
    Metal badges are earlier. The early ones had the “fastback“ style flat air filter like other saws of that time. Later ones came with the HD set up that use the cartridge filter similar to your 400
  19. huskihl
    huskihl
    Personally the 10MM isn’t worth any more than a 12 to me because what the 12 gives up in power it makes up for in strength over the wrist pin and bearing. Nice ones bring more, beat up ones bring less
  20. huskihl
    huskihl
    10mm
    12mm 044/ 440
    046/460
    JD Guy, eatonpcat, Chvymn99 and 9 others like this.
