Finally - A better way to tie up tomato plants!
Discussion in 'The DIY Room' started by don2222, Jun 22, 2024.
  1. don2222
    don2222
    Salem NH
    Hello
    It was time to tie up the tomato plants and I always dread doing it!! This year a quick trip to Home Depot and bingo! Plant hold up clips! I never saw these before! What a pleasant surprise if they work! Took home a pack of 10 and the 100 feet of plant tie up with cutter! WOW easy peasy!
    I already bolted in pressure treated 2x4s and used a piece of electrical conduit as a tie bar so just wrap the wire around it and pull the plant up before I twist it tight! Then as the plant grows I can untwist the wire and or change the clip to readjust it!!
    We used approximately 2 clips per plant. Your results may vary. :)
    Plant tie up clips
    https://www.homedepot.com/p/Vigoro-Reinforced-Plant-Clips-10-Pack-5586/322277969
    Plant tie up wire
    https://www.homedepot.com/p/Vigoro-...rden-Wire-With-Case-And-Cutter-5518/322301276
    John D, MikeInMa and theburtman like this.
  2. bogieb
    Probably a newer product to hit B&M stores and to be a Vigaoro product. I'm pretty sure I saw mine in a gardening catalog (maybe Vermont Seed?) and ordered them to hold up grape plant stems (which I had at my old house - so at least 15 years ago. I got a couple of packages of various sizes to clip stems directly to chain link fence.
    Illinois Industrial Tool made them back then (yes, I went and looked at the mesh bag they came in - because I save everything :emb:), but doing a Google search, I don't see them available anymore. The same type that I have are available all over Amazon though
    John D and don2222 like this.
  3. don2222
    don2222
    Salem NH
    That is a good price on Amazon!
  4. Jeffrey Svoboda
    Jeffrey Svoboda
    Why not just cage them while they're still small? Plus they can be reused year after year. That's all I've ever seen done to hold up tomatoe plants.
    morningwood and John D like this.
  5. billb3
    I use concrete reinforcement 'fence' and make cages from it.
    I also use T posts, putting a PVC T on top and running irrigation pipe thru the T.
    John D and Jeffrey Svoboda like this.
  6. don2222
    don2222
    Salem NH
    Sounds interesting. Can u post a pic of it?
  7. John D
    John D
    Syracuse ny
    This sounds smart because it includes irrigation
  8. billb3
    A cage: I usually tie two of these as a pair to a pole so they don't blow over in the wind.
    I did not grow Celebrity tomatoes this year so I am using them other ways.
    A trellis: with a couple of the cages strapped to a pole behind it.
    yooperdave, Woodwidow and John D like this.
  9. Eric VW
    Nice ingenuity Bill. :yes:
    Concrete mesh panels are really quite handy. :thumbs:
    John D likes this.
  10. Janina87
    Janina87
    NY
    I found it really helpful to explore a variety of solutions for my garden setup, which I also combine with my indoor plants. Shopping for indoor plants brings the greenery I love inside, and it's super reliable. Plus, I've enjoyed exploring various plant-support systems, similar to what's being discussed here, making my gardening both inside and out a breeze.
    John D likes this.
  11. yooperdave
    For the win! The ones I have are a larger diameter and work great-year after year. Being larger, I have never been concerned about the winds.
    For whatever reason, this year I decided not to use them. :doh: What a regret!
    During the winter months, I'll double them up and use them to protect the young apple trees from deer browsing Never had that problem either but you know how that goes.
    John D, eatonpcat and MikeInMa like this.
  12. MikeInMa
    I several of those coated wire coils/cutter. I use them all over the yard in with various applications.
    John D and eatonpcat like this.
  13. Barcroftb
    Barcroftb
    The Mitten
    I’ve got some romex electrical wire scraps that I’ve found dumpster diving new home construction sites. It works as good for tomato’s as it does for tree sapling tie outs. And when you’re done with it you can turn it in for scrap. Not sure I’ll ever scrap it as it’s useful for many things.
    John D, MikeInMa and eatonpcat like this.
