How often do you
Discussion in 'Chainsaws and Power Equipment' started by Chud, Jun 21, 2024.
  1. Chud
    Chud
    Change your drive sprocket? Just watched the WCS video at Oregon tool factory and the Oregon folks recommend replacing after 2 loops of chain.
    hmm I guess those 2010 261’s are due after using up several 100’ of chain :rofl: :lol:
    Horkn, Haftacut, Hinerman and 12 others like this.
  2. Jeffrey Svoboda
    Jeffrey Svoboda
    Recommendations are getting ridiculous. They're there to sell more product. I'm sure someone will tell ya it's cheap insurance to replace it. I say have a backup with if you're that worried about it and run it till the chain starts skipping.
  3. Eggshooterist
    Eggshooterist
    Erff
    Thats crazy talk. Need a new bar every 4 loops too? :rofl: :lol:
    I run them until its almost worn through as long as the chain isn't skipping.
  4. The Wood Wolverine
    I watch the wear. About here is close to where I change. I have so many chains in rotation I have no idea how many per rim.
    -in case this turns into the new rim hoarding thread;
  5. Screwloose
    I didn't know that they could be replaced. I thought you had to buy another saw. Boy i feel silly.
    Horkn, Barcroftb, walt and 17 others like this.
  6. John D
    John D
    Syracuse ny
    What you said is a great excuse to keep buying new saws
    When the old lady says why are you buying another saw just say the sprocket is showing wear and you can’t chance being down a saw
    Horkn, Barcroftb, eatonpcat and 11 others like this.
  7. brenndatomu
    His old lady has heard em all by now, no way would she buy that! :rofl: :lol:
    Dok440, Horkn, Barcroftb and 12 others like this.
  8. Screwloose
    That's so the truth!
    Barcroftb, John D, eatonpcat and 5 others like this.
  9. buZZsaw BRAD
    I never have. Years back my OPE dealer recommended replacing it on my 028 back in the late 80's. It was a spur sprocket. Thinking back it didn't look that bad.
    Do rim sprockets wear out?
  10. Chud
    Chud
    I’d say the wear is accelerated when a chain jumps repeatedly, the drivers get mashed and the chain is put back on and run without tending the drivers.
    walt, John D, brenndatomu and 2 others like this.
  11. Screwloose
    Yes they do, but not as fast as the manufacturer would like you to believe. Cheap to keep a one on hand but don't be concerned until it acts up.
  12. Wolley
    Wolley
    I guess the issue is the pitch changes as the rim wears out. That will stretch a chain almost instantly. It doesn't take much. So if you ever put a new chain on and it goes slack right away, that's probably it
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    How many of you have stretched a chain until it's broke? Let me simplify that a little more and say, has anyone had a chain break on them? Personally i have not.
    John D, Screwloose and buZZsaw BRAD like this.
  14. buZZsaw BRAD
    I have not either. Stretching the norm especially if I'm noodling.
    John D and Screwloose like this.
  15. The Wood Wolverine
    Yep. And had one tie strap break, caught it while grinding. Milling with a 10 horse ported big cc saw is hard on chain. Especially when you strike metal.
  16. Jeffrey Svoboda
    Jeffrey Svoboda
    Personally, I've filed into the tie strap pretty far while hand sharpening and trying different angles. Haven't had those break either.
  17. Jeffrey Svoboda
    Jeffrey Svoboda
    Obviously the extreme but still not a "broken" chain. I'm thinking 2 ends while it's still "mounted" on a running saw. Or a running saw and the chain is on the ground or thrown into the operator.
  18. The Wood Wolverine
    Yes, I’ve had that happen as well.
  19. Jeffrey Svoboda
    Jeffrey Svoboda
    First I've heard. I'm gonna keep pushing the limits until i get a broken one. At least then I'll know what it takes to break one and i can adjust my process from there. I assume it'll all depend on how much hp a saw has and the "bite" of the chain.
  20. MikeInMa
