Red Oak
Discussion in 'The Wood Pile' started by WoodPirate, Jun 20, 2024.
  1. WoodPirate
    WoodPirate
    Tennessee
    IMG20240606112607.jpg IMG20240606112601.jpg IMG20240606112620.jpg IMG20240606112624.jpg
    Man was it hot. Guy had a person cut down a tree. Cutter took all the small stuff then told him he did not have a saw big enough to cut the rest. Got the call to go look at it. 32-28 inch diameter. Time to start cutting.
  2. MikeInMa
  3. The Wood Wolverine
    The easiest splittin’ wood there is. :dex:
  4. jrider
    jrider
    Unless there's a crotch or a knot where a branch once was.
  5. Chud
    Chud
    The cutter could fell it and cut the trunk up, but didn’t have a big enough saw to take the big chunks? Did I read that right?
  6. MikeInMa
    I thought the same thing.
    T.Jeff Veal, JD Guy, Softwood and 9 others like this.
  7. buZZsaw BRAD
  8. Ronaldo
    Ronaldo
    Some guys just don't like dealing with the big stuff, do they. It is hard work but the wood adds up pretty quickly.
  9. WoodPirate
    WoodPirate
    Tennessee
    You are correct.
  10. WoodPirate
    WoodPirate
    Tennessee
    You are right . I just chalk it up to light weight . This is how I end up with the most of my wood.
  11. WoodPirate
    WoodPirate
    Tennessee
    Slow and steady as it goes. Can not believe how much liquid you can go through when doing this in warmer than normal heat. It’s all good.
  12. Backwoods Savage
    You are very kind saying it is warmer than normal. Most say it is hotter than....
  13. WoodPirate
    WoodPirate
    Tennessee
    You are so right about the heat. Try to keep it clean here, nice folks on here .
  14. SD Steve
    SD Steve
    South Dakota
    Ash is pretty nice, but I've never had Oak that I split
  15. WoodPirate
    WoodPirate
    Tennessee
    Did I say it was HOT? Finally got it done and home. Now to split and stack. Did I say it was HOT? Stay safe and hydrate. Enjoy the pics.
  16. buZZsaw BRAD
    eatonpcat, WoodPirate and John D like this.
  17. WoodPirate
    WoodPirate
    Tennessee
    Thanks Brad. It’s the only way a feller like me can roll. Now waiting for a window of cooler weather to split and stack. Stay safe and hydrate.
    eatonpcat, John D and buZZsaw BRAD like this.
