My XS460 needs a diaper!
Discussion in 'Chainsaws and Power Equipment' started by Screwloose, May 8, 2024.
  1. Screwloose
    After a run at Dennis's my 460 has developed a incontinence issue.
    It also has a less than stellar oil delivery.
    I'd like to replace the pump with a high output one and replace any rubber parts at the same time.
    Does anyone have the IPL or the part numbers? My dealer has a new parts guy and I'd rather just give them the numbers.
    I'm sure someone like huskihl has them memorized.
    Thanks, Keith
    T.Jeff Veal, Chaz, eatonpcat and 5 others like this.
  2. brenndatomu
    My 290 has always marked its spot too...I think the oil pump is made by HD :whistle: :D
    T.Jeff Veal, JD Guy, Chaz and 7 others like this.
  3. The Wood Wolverine
    :doh:
    T.Jeff Veal, JD Guy, Chaz and 6 others like this.
  4. RCBS
    Nothing to worry about. It's just sweat from all the horsepower!
  5. JRHAWK9
    JRHAWK9
    Wisconsin
    My 346XP developed a leak a handful of years ago. I fixed it a couple years ago by simply replacing a couple lines. The system used in the 346/350's are known to be leakers I guess.
    T.Jeff Veal, Chaz, RCBS and 5 others like this.
  6. chris
    it helps to crack open the oil tank for bit after you are done for the day. bit of pressure builds up. the old hot engine heating up a liquid which is looking for somewhere to expand to.
  7. Screwloose
    I can give that a shot. Still puts out a dismal amount of oil though.
    T.Jeff Veal, Chaz, eatonpcat and 3 others like this.
  8. John D
    John D
    Syracuse ny
    Has the filter ever been changed
    Maybe just replace all the oil lines
  9. huskihl
    huskihl
    I don’t know the part numbers but you want the oil pump from an MS 460R or 461R. At about 1/3 of the price you can buy just the R piston and R control bolt and do the work yourself in about a half hour. I would replace the oil line, degrease everything, and use a sealant when you put it back together
  10. Screwloose
    Put the sealant on what?
  11. huskihl
    huskihl
    The hose lightly taper-fits into a hole in the case. And the oil pump lightly taper-fits onto the hose. Use sealant on both sides of the taper
  12. Screwloose
    Gotcha. When I did my 026 I just pushed it together. What is your sealer of choice?
  13. huskihl
    huskihl
    I use Motoseal because that’s what I have laying there. I have heard others used silicone with good results. I would actually think silicone would be better
    brenndatomu, eatonpcat, RCBS and 2 others like this.
