The Woodyard Abhors a Vacuum
Discussion in 'The Wood Pile' started by Eric Wanderweg, Mar 19, 2021.
  1. Eric Wanderweg
    Thanks, that’s actually my goal :handshake:
    I do the majority of my hoarding October-April, then stay busy with other things during the summer. Of course I still end up cutting a little here and there, but I save the bull work for cooler temperatures.
  2. buZZsaw BRAD
    Liking that vertical 2x8/2x6 end support.
    Personally I think you should add onto the shed. :stacker:
    Valuable storage for firewood the splitter is taking up.:D
  3. Eric Wanderweg
    I recently had a bad experience accidentally leaving my splitter uncovered during a rainstorm. Usually I throw a tarp over it when I’m done using it, but forgot to one day. Rained like crazy overnight. The next morning my heart sank when I saw what I had done. Sure enough water got into the engine. Pulled the spark plug and carburetor and cleared it out. Changed the oil again too even though it had about 2 hours on it. No damage thankfully but never again. :hair: That machine is deserving of a spot under the roof from now on. As for my shed, it’s as big as it’s going to get. Marriage, compromises and such :whistle: I do like the single rows stacked up against dimensional lumber. No cribbing to worry about and I get plenty of airflow in between the rows. Even with the gaps in my shed now I still have more packed in there than I did before.
  4. buZZsaw BRAD
    JBYB buddy as you know. I was at bundle wood storage this afternoon talking to my friend. He already OKed replacing the right side of the shed but didn't have a problem if i added onto the left side. It's be 8.5' long and 5-6' tall stacks three rows wide. It would take the place of the cord and a half of wood I had stacked behind his shed. His bride to be complained even though its not seen from the house. :picard:
  5. John D
    John D
    Syracuse ny
    BuZZsaw has a great point
    Maybe just a little lean to so the splitter has its own space
  6. Eric Wanderweg
    That was the plan, and I am saving several cedar posts to build one at some point, but I think that’s going on the back burner for now. Too many projects at home this year. Not to say I wouldn’t rather be working on more redneck outbuildings ;)
  7. John D
    John D
    Syracuse ny
    I completely understand between work and house projects that have to get done other things have to wait
  8. The Wood Wolverine
    Stacks look great as usual Eric. :thumbs::thumbs:
  9. Eric Wanderweg
    Yesterday I snagged a few rounds of reasonably solid dead ash. It’s in the mid 40s and raining here, which isn’t exactly splitting weather. I’m feeling like a dirt farmer millionaire splitting these rounds in my woodshed out of the rain :thumbs:
    19B942D4-EE33-4D96-B76A-D66E48FDCBB9.jpeg D4AEA844-1D40-484C-B5D0-41D6908C79AB.jpeg
  10. John D
    John D
    Syracuse ny
    That’s a nice snag it’s also nice you can split out of the rain
  11. Eric Wanderweg
    I have a wood delivery to make to a younger couple later this week, friend of a friend type deal through my wife. They must have a small stove because she said she can only burn 13” max splits. I assume this is North-South orientation. Anyway, normally I wouldn’t do this but… here I am. I made a rack for ganging up the splits and bucking them shorter (they’re 16-18” currently) It works but it’s laborious. If she wants to become a regular customer I’ll have to cut 13” rounds specifically for her in the future.
    I think I’ll set a stop on my miter saw tomorrow and do them individually. There’s a lot of waste in saw chips here. I’ll burn the leftover pieces myself.
  12. The Wood Wolverine
    Miter saw will slow you down significantly. Lotta waste either way with the short chunkies left over. Price just went wayyyyy up.
    :makeitrain"
  13. stuckinthemuck
    stuckinthemuck
    The way I did it was on the miter saw. My splits are 18” plus or minus an inch. The customer who wanted 14” splits received the same amount of wood we usually sell but for each split he received a 14” piece and a chunk. So the tiny amount of kerf from the miter saw came out of his pocket. I don’t think I would do 14” rounds specifically for this customer. I will just continue to cut down already dried 18” pieces. Of note, we only sell about 1/10th of a cord at a time. So it’s not a lot of wood to process. 14” pieces processed. Chunks in the paper bags.
  14. chris
    sometimes i have to cut some down, run them through the bandsaw, way faster than the miter saw and some splits are bigger than the 12" miter can process
  15. brenndatomu
    I ran a Kuuma VF200 furnace one winter, it took 16" splits, I stock 22"...so I cut 6" off all the splits that winter using a miter saw...I bought the larger Kuuma furnace for the following winter.
  16. buZZsaw BRAD
    X2. Mitre saw on the dangerous side too. I use one on a regular basis and wont do that.
    Sweet job on the jig and hope your charging extra.
  17. T.Jeff Veal
    If she wants to become a regular customer, cutting her wood/rounds the correct length first works great.
    We have a couple customers that need 14" splits.
    We just make a few totes of that length and some 16". Our regular length is 18"
    14" splits fit across the tote in 3 rows... 20250502_130655.jpg 20250502_114230.jpg 20250502_130655.jpg 20250502_114230.jpg
  18. Eric Wanderweg
    Nice looking splits. I could use some of those IBC totes myself but then I'd need to buy a tractor with a loader to move them, and once I had that, a sawmill would be in order... :whistle:
  19. T.Jeff Veal
    Well, you use them for storage.
    eatonpcat, theburtman, John D and 3 others like this.
  20. Eric Wanderweg
    I’m finally caught up on processing and stacking the wood that’s been in my processing area since mid summer. This has to be the most mixed species partial row of wood I’ve ever stacked. Red maple, black locust, mulberry, black walnut, butternut, ash, white oak, and a few rounds of ironwood that buZZsaw BRAD donated to the cause last week. I’ll have a bunch of red oak to add to the hoard later this fall, but for now I’m done processing. It feels good to see the processing area cleared out and raked up. Who knows, maybe next year I’ll even be able to grow grass there :whistle:
