Finally some success
Discussion in 'Chainsaws and Power Equipment' started by Reloader, Mar 24, 2024.
  1. Reloader
    Reloader
    NW Oregon
    Purchased this old Shindaiwa 500 years ago. The previous owner had rigged up a repair to the rear handle.
    It had always been a good runner so it gets some use here cutting scraps and kindling.
    The other day I couldn’t get it to start. It would fire once with a shot of carb cleaner but then nothing after.
    1. Checked spark and compression and both looked good. I installed a new spark plug anyway.
    2. Pulled the carb and it looked fine after I pulled the covers but still no luck after reinstalling it.
    3. Replaced the carb and no luck.
    4. Just out of curiosity I checked the muffler screen and it was clear.
    5. Checked the fuel line in the tank and it had turned to mush. The end of it had closed completely which was a surprise as I had run it fairly recently with no issues. [​IMG]
    Replaced the fuel line and filter, fueled it up and no fire on cold startup with fast idle and choke closed.
    6. Zip tied the throttle to wot.
    10 cranks with the ignition off
    One crank with wot and ignition on and it fired up and runs great.
    I should have checked the fuel line first.
  2. RCBS
    Always feels good to be able to repair your own stuff.
  3. Locust Post
    Not bad for a saw you bought 500 years ago....:D
  4. Eggshooterist
    Eggshooterist
    Erff
    :thumbs::rofl: :lol::handshake:
  5. John D
    John D
    Syracuse ny
    Nice looking old saw
    brenndatomu, metalcuttr and eatonpcat like this.
  6. isaaccarlson
    isaaccarlson
    Colfax, WI
    Sounds like that 500 year old fuel line did it's job.
