leather gloves
Discussion in 'The Wood Pile' started by rusty ranger 44, Mar 24, 2024.
  1. rusty ranger 44
    rusty ranger 44
    south central Pa
    After doing a search on leather glove repair, with no results. I would have thought this topic would have been hashed out, however what do you guys do with gloves with the finger holes in them. Maybe its the quality of today's leather or are they being made with thinner leather? Looks like I need to give up my leather gloves and go to the latex dipped from HF
  2. Chud
    Chud
    Cheap or expensive, firewood splitting wears them out. I like the way spendy leather fits and feels, but it’s crazy to use them for firewood. For me it’s always the left hand glove that wears out first.
  3. theburtman
    theburtman
    I wear out the right fingers. I Gorilla Tape them for a while until the whole glove is spent. I use the latex gloves in warmer weather.
  4. Butcher
    Butcher
    I work in the mineing industry where you get into all sorts of stuff to ruin gloves. Tillman leather gloves are our go to gloves for what they go thru. Not much you can do when the fingers wear out no matter what you are useing unless you wrap duct tape around the holes. I used to and still do like the old yellow chore gloves you can get at TSC or most any farm fleet type store but last time I looked those are up to $25 a five pack.
  5. Wouldsplitter
    Wouldsplitter
    Illinois
    Turning the leather inside out gives you better grip on the wood and seems to make them last longer.
    I have also bought the expensive Buffalo skin gloves and they lasted much longer than cowhide.
  6. brenndatomu
    It was, a time or two now, but the search feature here will leave you wanting often times...
  7. Ronaldo
    Ronaldo
    I gave up on leather gloves for firewood duties. The dipped gloves last SO much longer and don't need any break in.
    Sent from my SM-S536DL using Tapatalk
  8. jrider
    jrider
    What kind of mining and what types of duties are you responsible for? Just curious.
  9. Butcher
    Butcher
    Sand and gravel. Heavy equipment operator, Classifier, wash plants, crushers, welder, you name it. The only thing I wont do is learn to work the dredge. That job makes a man crazy.
  10. iowahiker
    iowahiker
    NE Iowa
  11. BuckeyeFootball
    BuckeyeFootball
    I buy the cheap $3 a pair gray ones and will use them till almost all the fingers have holes.
  12. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Same here, but I don’t mind running the dredge. Out in the middle of the lake you don’t have to deal with anyone.
  13. Locust Post
  14. buZZsaw BRAD
    I was given a pricey pair of leather work gloves as a gift. Hated them for firewooding. PITA to get off if wet or sweaty. Generic latex dipped do the job. Use them, get holes, toss and repeat. I have thicker ones for cold weather. Ill recoat the latex when it wears on those.
  15. Hinerman
    Hinerman
    NE Oklahoma
    x2
    And they are cheap, $2-3 per pair. Even if I could buy leather gloves for that price, I still wouldn't buy them, the Atlas gloves are just better for firewood
  16. Yawner
    Yawner
    Louisiana
    Why does it do that? Just curious. Is it a dredge in a body of water?
  17. Yawner
    Yawner
    Louisiana
    ^^^ works for me. Until it doesn't.
  18. Farmchuck
    Farmchuck
    Nepa
    Where did you get your buffalo gloves? Need a new pair of gloves that are tough for fixing fence this spring (barbed wire):confused:
    Thanks!:)
  19. RCBS
    I tore up quite a few pairs of gloves making wood before realizing that there is no glove that will stand up to that particular chore well. I'm a bit of a glove fanatic at times and own many varieties. I have gloves specifically for splitting and stacking wood and then there's gloves for everything else. I get best wear from the wrinkly latex covered gloves at the splitter. I wear the 'foam nitrile' when using a saw or runnig the tractor or whatever. Much greater dexterirty but they don't hold up to handling wood at all. The thicker latex coating holds up better there.
    Wood handlers (have winter versions also)
    Everything else
  20. Butcher
    Butcher
    Kind of a company joke. The guys that are dredge operators here are just a little eccentric. Pic is our dredge pushed to shore for repairs.
