New chain. Dull or sharp?
Discussion in 'The Wood Pile' started by BC Doug Fir, Mar 19, 2024.
  1. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    Does anybody take a new chain out of the box and install it on your favourite saw and then take a file to it? I do. Took the original chain off the 572xp and filed the new one. Maybe I’m just picky.
  2. Wolley
    Wolley
  3. Eggshooterist
    Eggshooterist
    Erff
    Nope. Me either.
    metalcuttr, Hinerman, jrider and 4 others like this.
  4. Wouldsplitter
    Wouldsplitter
    Illinois
  5. Eckie
    Eckie
    I've never had a chain be as sharp as when it first comes out the box, even when a saw shop puts it on a machine. Don't know why I'd mess that up with a file.
  6. Barcroftb
    Barcroftb
    The Mitten
    Depends on the chain. Most chain I throw on the Simington to put a good work square grind on it. That’s usually quite a bit faster than stock;)
  7. Eric Wanderweg
    I'll use it first until it loses it's edge, then take the file to it. I'm unwilling to sacrifice any top plate length just because I don't fully approve of the factory grind :)
  8. spotted owl
    spotted owl
    PNW
    Every single chain get kissed by the grinder before touching the bar. Square grind, Oregon 75CK. Drop the rakers down to 30 thou. I want my angles set and ready for my wood not whatever the factory uses for the catch all.
    Strait out of the box works good, but. A well tuned and sharpened chain works better and is the best "mod" you can do for your saw.
    Owl
    metalcuttr, showrguy, John D and 2 others like this.
  9. BuckeyeFootball
    BuckeyeFootball
    Sometimes Ill hit the rakers thats about it.
  10. Camber
    Camber
    Montana
    I always hit them with a file, then do the rakers. I have never had a chain truly sharp or the rakers right straight off a roll. Teeth don't take much, but rakers are always screwy.
    metalcuttr and Backwoods Savage like this.
  11. MikeInMa
    I've never sharpened a new chain.
  12. walt
    walt
    north central ohio
    X 2
  13. Eckie
    Eckie
    Wondering where yall are buying all these new unsharp chains?? :rofl: :lol: :handshake:
    Just messing... Whatever works for you.
  14. RCBS
  15. John D
    John D
    Syracuse ny
  16. buZZsaw BRAD
    Nope.
    metalcuttr, John D, Hinerman and 3 others like this.
  17. JRHAWK9
    JRHAWK9
    Wisconsin
    yep, just did it the other day. Made two light passes on the cutters and then hit the rakers. I don't like how out of the box chains cut.
    metalcuttr, Camber and Wouldsplitter like this.
  18. Jeffrey Svoboda
    Jeffrey Svoboda
  19. Yawner
    Yawner
    Louisiana
    I don't like filing, so, I sure won't touch an out of the box chain.
  20. Wouldsplitter
    Wouldsplitter
    Illinois
    What do you use for a raker gauge?
    metalcuttr and Hinerman like this.
