261 Starter Rope Issue
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, Mar 18, 2024.
  1. buZZsaw BRAD
    Went to start the 261 yesterday and the pull rope came out very easily. Winds back up no problem.
    Is this an easy fix? I'm not messing with that coil spring inside. Tried that before with bad results.:hair:
  2. Duane(Pa)
    Duane(Pa)
    Centre Co.
    Take it off and check the plastic pawls.
    John D, metalcuttr and brenndatomu like this.
  3. Chud
    Chud
    Does it turn over? Did your decomp valve get depressed?
  4. MikeInMa
    See if Fiskars will honor the recoil rope.
    Nah.... never mind.
  5. JimBear
    JimBear
    This is what I am thunking also
  6. buzz-saw
    buzz-saw
    Ct.
    Meltdown?
  7. The Wood Wolverine
    I'm guessing it's a pawl issue as well. Pull the recoil cover off the saw and look at/check 'em out. Make sure there's no debris in there keeping them from doing their job.
  8. Meche_03
    Meche_03
    Missouri
    Sounds like prawls or little spring failed. Worst case is you can buy a complete side assembly. I had to on my 036. I went to start it without using the decompression and pulled the rope recoil assembly right through the side cover. The cover had cracks in it but I didn't expect a catastrophic failure that caused me to punch my self.
  9. brenndatomu
  10. brenndatomu
    I have a Honda GX390 engine with an aftermarket recoil on it...it sometimes doesn't engage...its about enough to spin ya clear around if you are givin 'er a good yank! :hair:
  11. buZZsaw BRAD
    Dont even use the decomp on the 261. It worked fine on Saturday. Ill have to take the cover off. Seems like the pawls aren't engaging.
  12. ole
    ole
    Rock County Wisconsin
    Give it good air comp blow out.
  13. Eggshooterist
    Eggshooterist
    Erff
    Maybe using the decomp would have prevented the pull start failure...
    John D, Ron T, farmer steve and 2 others like this.
  14. JimBear
    JimBear
  15. buZZsaw BRAD
    Sandhillbilly and brenndatomu like this.
  16. Eggshooterist
    Eggshooterist
    Erff
  17. John D
    John D
    Syracuse ny
    Today is a nice cold day to be inside working on that saw where it’s warm
  18. Eric Wanderweg
    Not for nothing but he does have like 17 other Stihls he could run :whistle: Plus the Stihl dealer is right in town for him. I imagine it's tempting to just have them deal with it....
  19. buzz-saw
    buzz-saw
    Ct.
    and he likes to work in this weather, plus he knows someone close that can probably fix a broken saw.:whistle::whistle:
  20. John D
    John D
    Syracuse ny
    It all makes sense now
