Need a new sprocket for my MS251
Discussion in 'Chainsaws and Power Equipment' started by cezar, Mar 14, 2024.
  1. cezar
    cezar
    KY
    My local Stihl dealer stocks NOTHING. So what should I order online from the aftermarket?
    farmer steve likes this.
  2. Ohio
    Not Ohio
    farmer steve and Eggshooterist like this.
  3. The Wood Wolverine
    I’m a fan of oem stuff. Aftermarket is a crap shoot.
    Here’s the difference between rim and spur in case you didn’t know. W/ a rim, you can simply replace the “sprocket”. On a spur drive, you have to replace the entire drum.
  4. cezar
    cezar
    KY
    farmer steve and metalcuttr like this.
  5. Ohio
    Not Ohio
    Eggshooterist and metalcuttr like this.
  6. Eggshooterist
    Eggshooterist
    Erff
    They can order it I would imagine. You are either waiting on it if they order it or if you order it.
    metalcuttr likes this.
  7. cezar
    cezar
    KY
    Absolutely sick and tired of this stihl bull****. I sincerely regret buying this brand.
    So is there a china knockoff I can buy for sprockets so I can avoid this hassle?
  8. Eggshooterist
    Eggshooterist
    Erff
    I don’t buy Chinese counterfeit products for my saws so I can't help you there. Someone already listed where you can order what you need up above.
  9. cezar
    cezar
    KY
    Well, I was hoping to convert to the rim drive but if I can't get replacement rims it is of no use to me. I'll wait to see if anyone else has a suggestion before I just go ahead and order the spur gear wolverine posted.
    I'll gladly buy chinese counterfeit products if my alternative is to drive an hour each way to a competent stihl dealer or put an order in by my local dealer and get blown off for two weeks and then told my stuff is never coming (true story!).
    Anyone want to buy a very gently used MS251 so I can get an Echo?
  10. The Wood Wolverine
    It’s not exclusive to Stihl. When I first started out I had a great Husky dealer very close. Stocked lots of stuff, awesome place. They got bought out by a chain store called Messicks. Went there a couple times for small stuff, have to order everything. Bad part was, and I don’t know if this changed, they told me they had to wait to place an order till they got $50 minimum. I quit going there and buy online now and some stuff gets to me in about a week. They also wouldn’t budge from 100% suggested retail price.
    Eggshooterist likes this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Ohio posted the link to the drum with rim. That same place sells just rims as well.
    Stihl Ms251, MS251C,Ms 241, Ms 231 Clutch Drum Rim Sprocket Assembly N
  12. cezar
    cezar
    KY
  13. cezar
    cezar
    KY
    And sorry, I'm not being intentionally obtuse. It just took me a long time to understand chain and bar specs and I still only have a tenous grasp on that. I just don't know how to find the correct matching part to this sprocket.
  14. Chud
    Chud
    The link is for your part. That’s how it displays for me.
  15. Eggshooterist
    Eggshooterist
    Erff
    I typed in stihl rim sprocket.
  16. Eggshooterist
    Eggshooterist
    Erff
    I believe he wants a spare rim as well
    cezar likes this.
  17. Eggshooterist
    Eggshooterist
    Erff
  18. MAF143
    MAF143
    North Central OH
    Stihl OEM Spur Sprocket .325" 7T MS 251 231 241 1143-640-2002 | eBay
    is just the OEM rim sprocket. kinda spendy. I've actually found that some parts are cheaper at the dealer...
    It has also been my experience that the rim sprockets last longer than the spur sprockets since they float side to side better on the clutch drum. The spurs tend to start a wear spot and then lock in on the spur at that spot and then eat it out quickly once the wear starts. hoping this makes sense but that's been my experience. I switch everything over to rim sprocket style and get much better life out of a rim sprocket.
    Maybe I've been lucky, but I never noticed a whole lot of difference in wear / longevity on OEM vs. knock off sprockets, but I have gotten a couple after market rim sprockets that were out of round a little. Just enough to notice tight, loose, tight, loose while rotating the chain during sharpening. Not sure if it matters much while cutting but I've tossed 1 or 2 out of a bag of 5 for that reason. I think I have spares of spares for everything anymore...
    brenndatomu and Eggshooterist like this.
  19. cezar
    cezar
    KY
  20. Eggshooterist
    Eggshooterist
    Erff
    Count the points on your original spur drum. If it's 7 points, get a 7. If it's 8, get 8. My guess is its 7.
    brenndatomu likes this.
