Oak anomaly?
Discussion in 'The Wood Pile' started by Chud, Mar 5, 2024.
  1. Chud
    Chud
    I grabbed some red oak today and one piece is not like the others. Maybe it’s the harsh roadside conditions, or herbicide, or a parent tree? It clearly looks like Northern Red Oak until the stump cut.
  2. John D
    John D
    Syracuse ny
  3. ThomH123
    ThomH123
    East Granby
    Are those trunk pieces? I see red oak with the corn flake bark in the north east. It could be a younger tree where the bark is not fully mature.
  4. MikeInMa
    The medullary rays are showing on both end cuts.
  5. Hickory45
    Hickory45
    GA
    Looks like a similar gradient to this red oak I had taken down recently.
    metalcuttr, ThomH123, Marvin and 3 others like this.
  6. Chud
    Chud
    Yes all trunk pieces. Southern Red Oak has a courser bark top to bottom, but darker wood. I’ll check some big older Northern Red Oaks for the difference. I don’t recall ever seeing this difference, but it may be a result of decay too.
  7. Chud
    Chud
  8. Eric Wanderweg
    I noticed on a lot of oaks that the bark near the base is usually rougher, getting progressively smoother further up the trunk. It almost looks like black oak on that one round, and regular red oak on the others. It all came from the same tree though?
  9. buZZsaw BRAD
  10. Chud
    Chud
    Here is a big one. The bark gets burly at the root flare. IMG_3272.jpeg IMG_3273.jpeg
  11. Hickory45
    Hickory45
    GA
    You made me curious enough to look closer at other red oaks around the yard. Here is a large mature one that has the popcorn bark only a few inches above ground level. Same size as the one in my last post that did have it going 5-6 feet up. And here's a small one that has it strongly. Wonder what causes it to be so much higher on some trees than others.?
    buZZsaw BRAD, metalcuttr and Chud like this.
  12. Chud
    Chud
    Those are good examples of the difference. It appears to be more pronounced on younger trees, or less apparent once the buttress widens out.
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    That makes me think it has something to do with the buttress widening rapidly to support the weight higher up.
    Maybe something to do with the amount of sway the tree has. Maybe the bark kinda cracks? Idk im just thinking out loud.
