Leaner
Discussion in 'The Wood Pile' started by The Wood Wolverine, Feb 29, 2024.
  1. Jeffrey Svoboda
    Jeffrey Svoboda
    I imagine it's so you can get your body into a better position to run if the need arises. It's just safer most times.
  2. jo191145
    yeah, can get a little further away. Safer unless that trigger snaps by itself while you’re not expecting it.
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    If i have a cut like that to make i imagine what size of dimensional lumber will hold the weight and lean. Think how much pull it takes to pull apart a 2x4.
  4. jo191145
    Understood. On the other hand if the tree isn’t live that 2x4 may be punky.
    I’m not saying ones right or ones wrong, just trying to understand why it’s done one way or the other.
  5. Jeffrey Svoboda
    Jeffrey Svoboda
    Oh i get it. That's kinda why you gotta pay attention while making your plunge cut and setting up your backstrap or trigger. Gotta feel where the good wood is.
    Similar to making a face cut and deciding where the hinge will be and how thick. I think its generally understood that the sap wood is stronger/more flexible/pulls apart harder. Obviously that's where the trigger will be set 9 times outta 10.
    I'm just rambling at this point. Lol. Try setting up a backstrap the next time you have a cut like that. It makes watching the fall funner cause you're on the back side of the tree instead of under/next to it.
    jo191145 and brenndatomu like this.
  6. The Wood Wolverine
    While cutting back away from the hinge to leave some trigger wood, the kerf started closing and pinching my bar. Had to use 2 wedges and barely got it out.
    RCBS, MikeInMa, brenndatomu and 2 others like this.
  7. Fanatical1
    Fanatical1
    Looks like a Chestnut Oak?
  8. The Wood Wolverine
    Yep. This is coming out of the same location as my oak honey hole thread.
    Coming out of a cut I felt the chain bump a rock. Had to swap.
    RCBS, Dok440, brenndatomu and 6 others like this.
  9. Canadian border VT
    Critique.. no
    It’s down
    No people hurt
    No real property damage
    That a:yes::yes:
    RCBS, Dok440, MikeInMa and 5 others like this.
  10. The Wood Wolverine
    I use a makeshift ramp to tumble rounds into the trailer so I don’t have to dead lift.
    Light they are not.
    179D0524-8188-40AE-8429-A9603889957B.jpeg A7D1598A-ACB3-4CC8-A29D-450FA798D2CA.jpeg F7DEB74B-10DB-4F5E-98BC-4BEAC7B596C7.jpeg
    RCBS, Dok440, Sandhillbilly and 8 others like this.
  11. Eric Wanderweg
    You are the official FHC king of chestnut oak!
  12. buZZsaw BRAD
  13. buZZsaw BRAD
    X2
  14. The Wood Wolverine
    No doubt! There is still so much more when I look around his skyline. Really glad I didn't mill this up. As I got to about 1/2-1/3 of the way down the log, I needed to start noodling rounds in 1/2. I started seeing heartwood rot. I told Tony I'll be sawing here for years to come.
    RCBS, Dok440, Sandhillbilly and 7 others like this.
  15. The Wood Wolverine
    :yes:
    Tony (the landowner) walked up to my fully loaded truck and commented on how good it smelled.
    Still have the base to get. Probably just a trailer load but there so much wood, I'll find enough to fill the bed of the truck. Counting 21" rounds I guessed a little over 60' of decent size rounds.
  16. The Wood Wolverine
    And this concludes getting the leaner wood home. No apts at work so I skipped out and got paid to hoard firewood. :dex:
    Noodled rounds and went in the woods to get some for the truck bed.
    Lot of rotten sapwood but there’s plenty of good heartwood to burn.
    13767540-A37E-4771-BFAB-26BF937DA038.jpeg Carried a few halves to the trailer and felt a muscle in my back tighten up. :( Took a little break and slowed down. I’ll be teetering later. :BrianK:
    2 layers of halves under the rounds. :dancer:
    Now I have something to split with the recent changes to my splitter.
    Just as I’m unloading the last pieces, it started to drizzle. More rain… :headbang::headbang::headbang::headbang:
    RCBS, Chvymn99, Dok440 and 6 others like this.
  17. Chud
    Chud
    Rained all day and still raining here. I scored some white oak but it’s too muddy to bring it home. :emb: That’s a good looking pile of oak you got there. It should fly through the splitter.
  18. The Wood Wolverine
    I haven’t burned chestnut oak back to back with straight white. I’m too familiar with chestnut but what I remember of the 2 times I did get white, it lasted a crazy long time in the firebox. And the whiskey barrel smell was much more pronounced.
    Soon as I get a break in the rain, I’ll give this new pump its maiden voyage.
  19. BuckeyeFootball
    BuckeyeFootball
    If its a live tree holding wood is expontentially stronger than hinge wood.
    buZZsaw BRAD likes this.
