Chains
Discussion in 'Chainsaws and Power Equipment' started by NYCountry, Sep 17, 2014.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    What kind of chains would u recommend to buy for stihl ms250 18" bar it seems the chains I buy at the local shop seem like garbage for $28 or should I sharpen it before I use even though it's new
  2. Grizzly Adam
    Grizzly Adam Guest
    I like Stihl 63RM61 for mine. Semi-chisel.
  3. SquareFile
    SquareFile
    somewhere
  4. PullinMyPoulan
    PullinMyPoulan
    Manistee National forest
    Check out baileysonline.com free shipping if your new to the site.I usually use the lpx or the woodland pro either way can't go wrong great prices good service.
  5. DexterDay
  6. SquareFile
    SquareFile
    somewhere
    I assumed that was the size since the OP didn't state the pitch
    If its .325 buy RS or RC stihl
    Tiewire likes this.
  7. NYCountry
    NYCountry
    Mohegan Lake NY
    I have the bar that it came with. I guess it's the stihl stock bar, so I will need a new bar regardless or can I just buy the chain. Should I get a stihl bar or do you recommend another brand bar.. Thanks (this is all new to me just trying to learn..
    Chvymn99 likes this.
  8. Tiewire
    Tiewire
    Missouri
    Clean and green wood stihl RS. Dry and dirty wood stihl RM.
    fox9988 and NYCountry like this.
  9. amateur cutter
    Yep, what he said. Although I run RS for the most part. I think the 250 runs .325 chain.
    Some Stihl dealers offer buy one get a 2nd chain 1/2 off.
    fox9988 likes this.
  10. Grizzly Adam
    Grizzly Adam Guest
    With this saw I don't notice a difference between the RS and RM other than RM holding an edge better.
  11. Tiewire
    Tiewire
    Missouri
    My stihl dealer will do buy 2 get one free a couple times a year.
  12. MasterMech
    The MS250 could have been sold with either a 3/8" Picco bar, or the more common .325 setup. If the original bar is still serviceable, I would buy a chain to fit that bar/sprocket. If the bar is heavily worn, I'd get a new bar. And on a 250, if I had a chance to convert it to Picco.......
  13. NYCountry
    NYCountry
    Mohegan Lake NY
    How can I tell if it's a picco bar and if it's not how do I go about getting it converted to picco
  14. MasterMech
    The bar should have some information etched into it near where it mounts to the saw. Otherwise you can tell by the chain or the sprocket/clutch drum will have the chain pitch (3/8P or .325) stamped into it.
    Conversion to Picco is straightforward. You need a bar, a chain, and a sprocket. I would use a rim sprocket kit which would have the rim sprocket itself, a new clutch drum and a needle bearing all in one shot.
    Pallet Pete and DexterDay like this.
  15. amateur cutter
    Picco Micro chain has a smaller cutter tooth & drive links. Bar should be labeled for, pitch, gauge, & # of drive links. Conversion is just the correct sprocket under the cover, & tip on the bar. Stihl has come out with an RS series picco chain that is very good.
    DexterDay likes this.
  16. amateur cutter
    Meh, He types faster & is smarter, but I still got the answer right.:D
  17. clemsonfor
    Yep was gonna say buy woodland chains from baileys they have free shipping on them now and there froably $14 or so for a chain for that saw
    Pallet Pete and NYCountry like this.
  18. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I ran a couple woodland chains they really didn't do bad at all until I hit a chunk of rebar. That was that I couldn't fix them..
    NYCountry and clemsonfor like this.
  19. Grizzly Adam
    Grizzly Adam Guest
    I thought you were a miracle worker!
  20. Pallet Pete
    Ovid
    I am but that chain had devil horns after that disaster... Seriously how does rebar get in the middle of a tree branch? :rofl: :lol:
    concretegrazer and NYCountry like this.
