Wood Stack Planning
Discussion in 'The Wood Pile' started by firecracker_77, Feb 25, 2024.
  1. firecracker_77
    firecracker_77
    IL
    Along the perimeter of my yard, I'm thinking about making a wood stack off the ground using cinder blocks and pressure treated lumber. Lowes sells 4 x 4 x 16 feet pressure treated pine for $31. Alternatively, I could have a bunch of gravel delivered or I could use concrete pavers that are at least as long as logs and lay them side by side around the perimeter. I don't want to put stack directly on the ground to avoid punky splits on bottom.
    What do others do?
    Theashhole, gwoods71, RCBS and 2 others like this.
  2. firecracker_77
    firecracker_77
    IL
    If I have 70 feet wall 4 feet high with 18 inch log length, that's over 3 cords and would be a season's worth for me
  3. Jeffrey Svoboda
    Jeffrey Svoboda
    I used cinder blocks and 8ft treated 2x6s. Blocks at the ends and middle.
  4. Reloader
    Reloader
    NW Oregon
    Trying to find a method of keeping it off the ground turned out to be a never ending job so I am willing to sacrifice a bit of quality on the lower row.
    It’s not a bad idea to elevate it if you can though, it’s just we get so much rain here whatever I tried would rot quickly.
    I put down some rubber conveyor belting and while this isn’t probably the best solution it does slow down the bottom rotting as it isn’t in contact with the dirt.
  5. blacktail
    blacktail
    PNW
    Pallets are often available for free.
  6. MikeInMa
    Look into the $'s of pressure treated landscape timbers. On sale are cheaper then 4x4's.
    My racks are 8ft. Makes counting cords easy.
    I use 2x4's or branches for uprights.
    In your case, sting them end to end.
  7. BuckeyeFootball
    BuckeyeFootball
    Pallets you can get them free. If you want them higher off the ground double them up. Broken ones can be used for kindling to and you can burn them after 3-5 years when they start failing.
  8. JDU
    JDU
    Perry County, PA
    Like others said, pallets are free and work. If you single stack, cut them in 1/2 long way. When they are done, good campfire/bonfire wood.
  9. 203coffeeman
    203coffeeman
    Connecticut
    Or u could get plastic pallets.
  10. Backwoods Savage
    How about just laying some logs on the ground and stacking on those? Pine may work the best for this. I just can't see spending dollars for something to stack wood on. The last several years I've been using dead some questionable pine for stacking on and it is working nicely. Cost is zero dollars.
  11. John D
    John D
    Syracuse ny
    I stacked my wood along the back and side backyard fence it is like I am building a privacy fence
    gwoods71, buZZsaw BRAD, RCBS and 2 others like this.
  12. John D
    John D
    Syracuse ny
    I never thought of cinder blocks
    That is a good idea
  13. Jeffrey Svoboda
    Jeffrey Svoboda
    If you get creative and find a construction site where they're digging out an old foundation, you might be able to get a few for free.
    If you end up using cinder blocks put the flat sides up and down so there's more surface area in contact with the ground. They'll sink in less that way.
  14. RCBS
    Skids aren't too hard to come by usually. I have found another way, but it doesn't allow for airflow underneath. I've been taking the bark that comes off the red oaks I process and 'lining' the ground with them, bark side up under my stacks in the woods. It seems to be working very well! Had some on it for a year and the bottom piece is prettywell in as good of shape as those above it. Just stacked some yesterday after tossing down some bark as a matter of fact. Long ago I used to take lesser quality splits and make runners out of them.
  15. The Wood Wolverine
    There’s an abundance of plastic pallets available in my area so that’s what I stack on.
    Marvin, JDU, buZZsaw BRAD and 7 others like this.
  16. John D
    John D
    Syracuse ny
    Very impressive
  17. PatrickNY
    PatrickNY
    Putnam County, NY
    Found these PT boards by the side of the road, but if I was buying them, I'd buy 2x4s, not 4x4s.
  18. Canadian border VT
    these are 2 12 foot metal racks 5 foot tall buddy of mine made from reclaimed sprinkler pipes
    1 and 1/2 inch BIP black iron pipe
    Marvin, John D, buZZsaw BRAD and 4 others like this.
  19. Brad M
    Brad M
    Pleasant Hope MO
    I put 48” x 12’ black plastic directly on the ground. Then I poke holes up and down the length with a pitchfork. Then 2 double rows of landscape timbers with t-posts on the ends. Two rows of 20” logs 4’ high gives you 1.25 cords. Holes in the plastic lets water drain during rainy weather and creates sort of a vapor barrier during drier weather.
  20. firecracker_77
    firecracker_77
    IL
    Impressive stash
