Long log fire
Discussion in 'The Wood Pile' started by Sandhillbilly, Feb 10, 2024.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Has anyone ever tried one ? I have been toying with the idea of doing one or two next year at the local Christmas walk about. I’m reasonably sure that I could borrow a steel feed bunk or two from some rancher. Thinking of putting a layer of sand or fine gravel in the bottom.
    The new barrels with the snowflake cut outs were a big hit, now I have a tough act to follow and up my game a bit more. Swedish candles or torches are also under consideration. But I think long log fires would be pretty cool, err, warm rather for more people to gather around. Setting the downtown on fire…part 2
  2. brenndatomu
  3. Buttermilk
    Buttermilk
    Central AR
    Don't know if it works well without smoking the place up, but it does look cool.
  4. JimBear
    JimBear
    Are you talking about burning a whole log ? Like 8’-12’ long ? If that’s what you are thunking then I would think it will be hard to get it dry & it will end up smoking something terrible.
    If you going to use “bunks” , I would think you could just stack some splits the length & get a good clean burn on.
    Old propane tanks/boilers cut in half lengthwise would work well, they won’t warp/disfigure like lighter thinner bunk material will. Plus the thicker steel will absorb & radiate a bit of heat also.
  5. SimonHS
    SimonHS
    Yorkshire, England
  6. SimonHS
    SimonHS
    Yorkshire, England
  7. Jeffrey Svoboda
    Jeffrey Svoboda
    If that's the case it won't work very well to warm people up, over half the flame is cover! What's the reason to burn like this in the first place?
    brenndatomu likes this.
  8. The Wood Wolverine
    You could build a larger scale one of these.
  9. Buttermilk
    Buttermilk
    Central AR
    I've sat around one built like that and with good seasoned wood it worked great.
  10. MikeInMa
  11. Sandhillbilly
    Sandhillbilly
    I was thinking mostly along the lines of As Thick As A Capercaillie: How To Build A Long Log Fire one.
  12. Sandhillbilly
    Sandhillbilly
  13. Sandhillbilly
    Sandhillbilly
    Can’t really have something like this on an asphalt street surface
  14. MikeInMa
    Weld barrel halves together. You might need to weld in cross supports when/if the tops and bottoms are removed.
    A few cinder blocks underneath should cradle/hold it in place.
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Not sure about "can't" but probably shouldn't. Like some said, long propane tank or maybe anhydrous? I doubt the local Co-op would even miss them.
    JimBear and Sandhillbilly like this.
  16. buZZsaw BRAD
    Kinda what i was thinking too.
  17. Sandhillbilly
    Sandhillbilly
    I can’t see going through that much effort to build something when I could borrow a feed bunk or two. A bunk would be heavier steel also
  18. Sandhillbilly
    Sandhillbilly
    The annual event is coming up on December 5th I believe.
    Gonna do practice run tonight. Standing dead elm logs about 5 1/2 feet. Made some steel saddles to help keep the logs in position.
    Kinda hard to get a matched set of 3 reasonably straight logs in this country. If this goes well tonight I have 3 more picked out that are 9’6” and a little larger diameter for the main event downtown. I’ll light it up shortly after sundown and get y’all some pictures IMG_2084.jpeg IMG_2086.jpeg IMG_2087.jpeg IMG_2088.jpeg
    WESF, Stephiedoll, Skier76 and 9 others like this.
  19. MikeInMa
    Looks like the inspector made sure all is well!
  20. Sandhillbilly
    Sandhillbilly
    JimBear, brenndatomu and MikeInMa like this.
