Bark and waste removal
Discussion in 'The Wood Pile' started by Gavorosalini, Feb 11, 2024.
  1. Gavorosalini
    Gavorosalini
    Hutchinson KS
    Any body else use a little forced air to burn their bark and splitter trash? Definitely speeds up the process.
  2. RCBS
    I've been collecting what leavings are practical to save for kindling. I usually take excess bark to the brush pile to burn.
  3. Reloader
    Reloader
    NW Oregon
    That should warm it up. I use blowers quite a bit on the brush and debris piles.
  4. Chud
    Chud
    I burned some scrap yesterday
  5. Gavorosalini
    Gavorosalini
    Hutchinson KS
    I will get a few decent kindling pieces sometimes. This however was a dead American elm with some bark falling off and some taking quite a bit of effort to take off. Some pieces just crumbled instead of split, so they ended up in the barrel too.
    We don't do the brush pile anymore. It grew way to fast and was way to close to a cedar row that I didn't feel comfortable burning it. Ended up taking a 40 yard roll off dumpster and 4 7x14 dump trailer loads to get rid of it all.
  6. metalcuttr
    metalcuttr
    western WA
    I am given to understand that a bit of magnesium will hasten things along also!:whistle:
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    I try to keep splitter leaving as well for kindling and mix it in with the stacks. I keep some bark but most gets tossed to the brush pile at Bunny's or low spots around her place.
  8. Dok440
    Dok440
    NorCal
    We are only allowed a burn pile 4' by 4' and they actually fly a plane around to monitor it. As a result I can never get rid of all the branches and splitter trash before things get dry and burn days go away. I burn as much splitter trash as I can in the fire pit. I also have several brush piles throughout the property. I did buy a grapple for the tractor so I can more easily grab a bunch from a brush pile and drop it on the fire. Can't wait to see if this works this year.
    Horkn, Cash Larue, MikeInMa and 3 others like this.
  9. Dok440
    Dok440
    NorCal
    Back in the day the best source of magnesium was VW engines. :dex:
  10. WoodPirate
    WoodPirate
    Tennessee
    Cleaned up some splitter scrape. Trying to stay ahead of the clutter. IMG20240207171944.jpg
  11. buZZsaw BRAD
    Most of mine gets left for mud control or tossed into the woods. I will from time to time have an empty feed bag next to the splitter for wood shards.
    Timberdog, Horkn, Cash Larue and 4 others like this.
  12. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve only got two logs left from 3 16ft dump trailer loads of standing dead elm. There was quite a bit of bark and punky stuff. It is actually a little bit tricky walking and working around the splitter right now. I’ll sort through the debris and grab a bunch of decent kindling. The rest will get swept up with the grapple on the skid steer and hauled to the village tree dump in my recently purchased dump truck.
    Once in a while I’ll have a burn barrel going when I’m processing, and throw stuff in it but punky stuff is always wet. Easier for me to haul it off
  13. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    I rake up everything and it goes into trash cans and then into the smoke dragon. Had a couple dry falls and a dry winter so the wood yard is clean sort of.
    Horkn, Cash Larue, metalcuttr and 3 others like this.
  14. RCBS
    I'm at the opposite spectrum. I sometimes haul stuff to the burn pile that I could discard elsewhere just so I can have a fire. haha Currently picking up sticks building a nice pile on the river lot.
  15. Wouldsplitter
    Wouldsplitter
    Illinois
    I can't seem to get it dry enough to want to burn it. Plus it makes a lot of ashes. Would it be easier to burn on a burn pile? Or is that not an option?
    RCBS and Cash Larue like this.
  16. BC Doug Fir
    BC Doug Fir
    Cariboo BC
    It dries good in a week without rain. Usually we have a fire ban all summer. As far as ash goes I might haul 3 steel buckets a year. The Douglas fir doesn’t leave much ash. Aspen on the other hand…..
    RCBS, Cash Larue and buZZsaw BRAD like this.
  17. Cash Larue
    Cash Larue
    Pine, CO
    I rake my scrap into a big pile and burn it in my solo stove. My boys roast marshmallows over it. The big chunks go into my Jotul wood stove. I don’t waste anything ;)
  18. Horkn
    I save my bark and it goes on the ground by my staging area. That area has been growing higher every year.
    metalcuttr, Cash Larue, RCBS and 3 others like this.
  19. BuckeyeFootball
    BuckeyeFootball
    Burn the bark in the pit, some gets used to fill low spots etc, and a small amount gets used in the stove. As for brush some gets hauled to the pit and some I use to make piles for rabbits.
  20. RCBS
    I have basically 'mulched' the area under my lower stacks with bark. I found it to be a great moisture barrier on the ground also and have it underneath stacks in the woods. Have a pile of it by the woods stacks just for that purpose. A lot of the red oak I process readily lets go of it's bark in sheets. Throw em on the ground where you need them (outer bark facing up) and stomp em flat.
    metalcuttr, Horkn, sms4life and 5 others like this.
