Viewing glass
Discussion in 'Modern EPA Stoves and Fireplaces' started by 203coffeeman, Jan 8, 2024.
  1. 203coffeeman
    203coffeeman
    Connecticut
    What do u clean the glass with to get the crap off. I used to have a bottle of stuff a customer gave me. I moved and now it’s gone. And my customer is no longer around to ask what it was.
  2. MikeInMa
    This works well for me.
    Horkn, Backwoods Savage and wildwest like this.
  3. Butcher
    Butcher
    A wet piece of news print dipped in wood ash from the stove. Rub a little and clean with a dry piece of np and use the np to get the stove started again. Not sure about you or any one else's stove but my Jotul manual says not to use any type of amonia based glass cleaner on the glass.
    blacktail, KSPlainsman, Horkn and 6 others like this.
  4. Ohio
    Not Ohio
    I use a small piece of damp paper towel and stove ash. It works better than anything else I have found.
  5. wildwest
    I'd suggest using the search bar here on this site.
    Horkn and Backwoods Savage like this.
  6. Backwoods Savage
    Another vote for a damp newspaper dipped very lightly in ashes..
    Horkn, Eric Wanderweg and SimonHS like this.
  7. SimonHS
    SimonHS
    Yorkshire, England
    And another vote for damp newspaper and ashes. Along with good old-fashioned elbow grease.
  8. saskwoodburner
    saskwoodburner
    Another vote for damp newspaper and ash with paper towel for the final wipe. Truth be told, as time goes on I personally care less and less about a perfectly clean piece of glass and just use the stove as a means of heat, not a pretty thing to look at.:D
  9. billb3
    I've never needed anything more than a wet paper towel.
    I had a little crusty build up in the corners once from a long time between wiping it down and a little ash did help.
    Stove is in the basement so I don't clean the glass every day, plus we burn fairly well seasoned wood so it's usually a thin grey film rather than crusty black stuff.
  10. wood and coal burner
    Quakertown,PA
    Windex. To keep it clear it needs to be cleaned every time a fire is started. As long as the stove is cold.
  11. Ron T
    Ron T
    Northeast Ohio....Bowdil
    Haven't cleaned mine at all this season. When I do it's newspaper and ash.
  12. Horkn
    A razor blade works great. No you won't scratch it.
  13. saskwoodburner
    saskwoodburner
    About every 4-6 weeks is perfect for my schedule:thumbs:
    Sandhillbilly likes this.
  14. buzz-saw
    buzz-saw
    Ct.
    Newspaper and ash. I picked this tip up here. For years my glass was black as asphalt. I tried this tip and , well ".......IT WORKS. I cound not believe it. First time in years I could see through it.
    KSPlainsman and Backwoods Savage like this.
  15. BuckeyeFootball
    BuckeyeFootball
    A rag or paper towel and ash. Usually clean it once a week.
    JimBear and Backwoods Savage like this.
  16. buzz-saw
    buzz-saw
    Ct.
    That’s about my schedule as well. First time it got cleaned. It wasn,t perfect since it was so bad.
    After cleaning it a couple times it is completely clear. It works amazingly well
  17. Backwoods Savage
    I too have yet to clean the glass this season and now probably won't until spring because I won't let the stove get cold until Spring as it is needed more for heat than for looks.
  18. BuckeyeFootball
    BuckeyeFootball
    Do you shut yours down low at night? That seems to be where 90% of my buildup comes from.
  19. JD Guy
    JD Guy
    Upstate SC
    Best product is “Dirtex” a little spray on the glass, wipe with paper towel and clean as new. No downside, professional painters use it for glass cleaner. Just me but I would never use a metal razor blade on glass. I’ve seen up close and personal the damage that can do to glass surfaces.
  20. Jeffrey Svoboda
    Jeffrey Svoboda
    Are you sure it wasn't the operator? :rofl: :lol::D
