Husqvarna 445 carburetor adjustment
Discussion in 'Chainsaws and Power Equipment' started by MNWood, Dec 23, 2023.
  1. MNWood
    MNWood
    Coon Rapids Minnesota
    Looking for someone with more knowledge to give me some tips related to adjusting the carburetor on my 2014 Husky 445.
    This spring I paid a shop to look at my carburetor. Instead of rebuilding it they replaced it with a genuine Husqvarna carburetor. It was running well right after that but then stopped sparking. I tracked that down to the ignition module.
    I recent replaced the ignition module, spark plug, air filter and fuel filter.. It starts right up but then runs like poo.
    I found a carburetor adjustment guide on the Husqvarna website and tried those steps without much success. What I'm wondering now is does anyone have a baseline setting for the three screws? for instance gently bottom them out and then turn out 1 1/2 turns or whatever. then fine tune from there. I know on many other engines those types of numbers are published but I can't find them for this saw. I would like to figure this out instead of going back to a shop. I'm pretty sure that it is an adjustment problem at this point. I have attached the carburetor section of the guide I found.
    Eggshooterist likes this.
  2. MNWood
    MNWood
  3. Chud
    Chud
    As far as I know 1.25-1.5 is baseline for everything. That’s what a small engine mechanic told me
    Eggshooterist and MNWood like this.
  4. MNWood
    MNWood
    after searching for a shop manual online I found these instructions and will try them tomorrow. No need to fire up a saw tonight and make my neighbors think I'm any crazier than they already do. :) Image 12-23-23 at 8.21 PM.jpeg
    Eggshooterist, MikeInMa and Chud like this.
  5. MNWood
    MNWood
    I found a video that seemed like a good mechanic posted that said 1 1/2 turns so I split the difference at 1 3/4 turns. Saw started right up and ran way better. Then I adjusted it a bit. Seemed like the throttle was sticking a bit and not always returning to idle as quick as it should. I popped the cover off and put a couple drops of PB Blaster on the cable and a couple other points. That made it snap back to idle like it should. I might purchase a pro line tachometer to set the H screw at 12,500 to 13,000 rpm. Regardless it is running way better now.
  6. Eggshooterist
    Eggshooterist
    Erff
    This is a good guide.
    https://www.madsens1.com/carburetor-adjustment-on-pro-saws
    MNWood likes this.
