Craft 4380
Discussion in 'Non-EPA Woodstoves and Fireplaces' started by Hashknife, Dec 16, 2023.
  1. Hashknife
    Hashknife
    South Carolina
    Hello!
    New to this forum and glad to be here. Been cutting, splitting, and heating with wood for 45 years.
    I like heating with wood and am in the process of prepairing a Craft 4830 for use in my house. The fire place is in the walk in basement.
    I found an almost unused one on FB marketplace for $200. Right now I'm fabricating a steel "transition" piece to go on the rectangle opening at the back of the unit. I have a SS chimney liner ordered and on the way. Im also making a few mods to be able to use the unit to blow hot air into the ductwork to heat the entire house. The original owner had the house built to accomodate this, and heated this house for many years untill he got to old to deal with handling the wood.
    I have a bigger cfm blower and have designed a way to duct it into the unit. It should work great.
    I'll post up pics as this project progresses.
    Thanks for letting me join yall! I appreciate it.
  2. Locust Post
  3. Hashknife
    Hashknife
    South Carolina
    Many Thanks!!
  4. The Wood Wolverine
    :handshake: You’ll love it here Hashknife.
    I’ve only been using wood for heat for the past 13 years but I grew up with it. Looking forward to your pics.
    Hashknife, T.Jeff Veal and wildwest like this.
  5. JD Guy
    JD Guy
    Upstate SC
    Welcome fellow South Carolinian!
  6. wildwest
    Nice to meet you, welcome to our club :) I googled the stove you listed and it seems really cool!
    Hashknife and T.Jeff Veal like this.
  7. T.Jeff Veal
    Welcome, neighbor. Love to see pictures of the progress. Good folks here on the forum
    wildwest and Hashknife like this.
  8. Hashknife
    Hashknife
    South Carolina
    Here is the Craft 4830 after unloading it at my house. It appears to be a "low mileage" unit.
    Built in Gastonia, NC in 1983.
  9. Hashknife
    Hashknife
    South Carolina
    Fitting a piece of steel to box the "exhaust" port at the back of the stove.
  10. Hashknife
    Hashknife
    South Carolina
    Building the transition flange frame out of angle iron.
  11. Hashknife
    Hashknife
    South Carolina
    Fabricating the transition "tower"
  12. Hashknife
    Hashknife
    South Carolina
    Plasma Cutting the stack hole
  13. Hashknife
    Hashknife
    South Carolina
    Fitting the stack snout.
  14. Hashknife
    Hashknife
    South Carolina
    Plasma cutting the square vent holes to accomodate 6" round ducting.
  15. JD Guy
    JD Guy
    Upstate SC
  16. Hashknife
    Hashknife
    South Carolina
    Still fabbin' & machining 35 years later!!
  17. wildwest
    brenndatomu and Hashknife like this.
  18. Hashknife
    Hashknife
    South Carolina
    Basically yes.
    I removed the stock blower unit. It is not big enough to push air into my house ductwork.
    The 6" holes allow a 6" duct to be connected to a higher CFM blower that will move enough air. The air will circulate around the stove and go out the other side into 6" ductwork that will go into an existing 6" hole in the house ductwork.
    Stock blower
    6" entry into house ductwork
  19. wildwest
    Cool!
  20. Hashknife
    Hashknife
    South Carolina
    Got the transition welded up and the chimney liner "stinger" mounted.
    The chimney liner was delivered earlier this morning.
