Tis the season for inspecting your set-up!!
Discussion in 'Everything Else (off topic)' started by Scotty Overkill, Sep 17, 2015.
  1. Marvin
    Marvin
    Huntingdon, Pa
    This. If my screen looks good I figure the flue looks good. However, if I get a nice warm day mid-season and there's no snow on the roof I might still take a peek just for reassurance sake.
  2. Warner
    I removed the screen when I had the cap off…
    T.Jeff Veal and Marvin like this.
  3. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Inspected the screen/cap, and cleaned the chimney today.
    Black ash, light and fluffy generally.
    Some "family" burned less than seasoned wood, but the setup looked good.
    The top of the wood stove got wet, so I might scrape and sand that briefly.
    Otherwise im ready for winter, one more chore off the list this summer. 20240803_082446.jpg
  4. HDRock
    I have been thinking about it , winter is coming but no stove or chimney preparation has occurred here yet, I think I will wait till it's not 85 outside to crawl up on the roof
  5. Sirchopsalot
    Sirchopsalot
    medium city in CT
    The other morning was cool enough for me to sneak up there.
    I waited till September last year, but that's a little late to fix something if parts are needed.
    We had a 62° morning, with a rainy day in front of us. Had it been too much cooler, I would have thought about a morning fire to take the chill off, maybe cook breakfast on.
    That I haven't inspected my setup can't be a reason I choose not to have a fire though.
    I should have dont that chore in May. Next year.
  6. Scotty Overkill
    I'll wait til around mid-September to go over both of my setups. Going to change the fireback refractory in my Napoleoon NZ3000 as well as the fibre baffle boards over the secondary tubes this fall also (already bought them) and I think I'm going to buy the HD baffles for the Napoleon 1900P in the kitchen (they're due for replacement also). As hot as it's been all summer it's hard to believe the cold is coming.
    Shoulder season will be here before we know it. But let's not wish summer away just yet!
  7. MikeInMa
    Winter is coming
  8. Eric Wanderweg
    I'll get up on my roof sometime around mid-September to do the cleanout. It's been 2 years since I'd last done it ( better wood = less cleanings ). I average around September 20th for a first fall fire. Other than that, I'm almost ready for another burning season :)
    brenndatomu, MikeInMa and theburtman like this.
  9. MikeInMa
    Both a new SS cat, from Condor, arrived yesterday. And a full gasket kit for the wood stove. I'll need to research what size/thickness goes where.
    brenndatomu likes this.
  10. MikeInMa
    I just made an appointment with chimney sweep for this Friday morning.
    I'll remove the stove top to access cat and insulation. The cat will be cleaned in diluted vinegar/water
    I'll check all gaskets, which were replaced last year.
    Can burning be all that far-away?
    WeldrDave, billb3 and eatonpcat like this.
  11. MikeInMa
    The sweep just left. All's looking good.
    As he was getting set-up, he asked how much wood was burned since the last cleaning, which was last summer. I told him just shy of 4 cords. His eyebrows went up and mentioned the rule of thumb was a cleaning after each cord burned. I smiled and explained the 3-year program. He didn't become a believer until he opened his vacuum and there was barely a covering of soot/creosote in the bottom. I did ask if he started with it empty. He had. He commented to keep doing what we're doing. Oh, I intend to.
    A couple of before/after
    I'll let the cat soak for a few hours.
    All set for another year.
  12. WeldrDave
    Looks Good Mike! :cool: I'll do mine in October when it cools off :dennis: Last year I got about a 2 gallon bucket full of soot, wasn't bad at all. Mine looked very similar to yours..
  13. Wildbill
    Wildbill
    SW Va
    Just got my oldest to drop the flame shield on my Buck 91 to check the CAT. No fly ash or clogging. Cleaned the chimney, should be ready to go! It's amazing to me that since going to a CAT stove that cresol isn't a problem anymore.
    Won't be long until the snow starts flying!
    Chvymn99, MikeInMa and theburtman like this.
  14. The Wood Wolverine
    Just got up on the roof a couple weeks ago and this is what I saw(yes, pre-sweep pic). 3 full seasons worth. I didn’t even get a full cup of stuff out of it. :dex:
    T.Jeff Veal, HDRock, Chvymn99 and 5 others like this.
  15. Scotty Overkill
    *BUMP* just a reminder for everyone to inspect your setups, go to the beginning of this thread for a checklist of items to look at prior to firing that stove up for the 2025/2026 heating season! If you have anythimg to add to this list, feel free to do so! Be safe and God Bless!
    HDRock, Chvymn99, theburtman and 3 others like this.
  16. Eric Wanderweg
    After getting small birds in my stove on 3 separate occasions now, I finally smartened up today after sweeping my stove pipe. I’m also glad I checked everything out because it’s time to fix the seam where the pipe meets the roof.
  17. Scotty Overkill
    Keep an eye on your spark arrestor. Even though I burn very well-seasoned wood, in the heart of winter when temps are very cold I get some buildup on the arrestor. I keep an eye on it snd clean it when necessary.
  18. Eric Wanderweg
    I definitely had a little buildup on mine underneath the top especially. A little super clean, a wire brush and then scotch brite got it good again :salute:
  19. The Wood Wolverine
    The only reason I haven’t put one of those on mine is the frequency of needing cleaned. I’ve only had a bird nest in my flue once but that was pretty bad. Then I had a bird in the stove once. I really don’t want to but probably should.
  20. MikeInMa
    Just had the stove chimney swept.
    Same as past years. Bottom of vacuum had very little in it. 5he man said we could go with cleaning every other year. We'll stick to annual cleaning.
    Soaking cat in water/vinegar mix before putting stove back together.
    Don't forget your off-season cleaning/maintenance.
