Started G200 today
Discussion in 'OWB's and Gasification Boilers' started by farmer rob, Nov 23, 2023.
  1. farmer rob
    farmer rob
    Dundalk Ontario Canada
    Finally I started the G 200 for the heating season is my second season with it so fingers crossed it performs as good as last year.Now to get wife to fill it and should be smooth sailing all winter.I will let you know wood use in spring and btw we just heating 200 floor house & its basement in Ontario Canada
  2. farmer rob
    farmer rob
    oops 200 should be 2000 dang typos
  3. Farmchuck
    Farmchuck
    Nepa
    Heatmaster?
    metalcuttr, savemoney and brenndatomu like this.
  4. brenndatomu
    There was a G200 and G400 Heatmaster...then they changed it to a G4000 in about 2020 or so.
    G4000, 7000, and 10,000 now, as you already know.
  5. Farmchuck
    Farmchuck
    Nepa
    That’s what confused me. I never heard of a
    G2000
    metalcuttr and savemoney like this.
  6. farmer rob
    farmer rob
    Yes a Heat Master G200 heating a 2000 foot house with basement temp is set for 74 day time 72 at night
    I bought the unit spring of 2020 but never built the new house till 2022 and so it sat in my shed till the 2 car attached garage was ready for it now it in the garage working as it should. A by product is my garage stays at 60+ degrees with no extra cost as I leave the back door open
  7. Farmchuck
    Farmchuck
    Nepa
    Nice!!!
  8. Farmchuck
    Farmchuck
    Nepa
    Do you get much smoke in the garage when loading it Rob?
  9. farmer rob
    farmer rob
    None that I can notice as for the most part this thing hardly smokes at all being a down draft and if done 2 times per day mostly just bed of coals if not glowing hot when time to refill.
  10. Farmchuck
    Farmchuck
    Nepa
    Do you have a nice stash of well seasoned wood for it?
    metalcuttr and brenndatomu like this.
  11. farmer rob
    farmer rob
    Yes I store all my wood in home made crates which are 4'deep 6'long & 5' high approx 110cubic feet I have a mix of slab wood (maple ash) some with maple body wood Poplar body wood and some with 3"x3" hardwood from pallets.
    I bring 3 into the second bay of the garage(where my truck parts when not using the Boiler) and put in a mix .I haul those from my Coverall building where the crates are double stacked for 4 plus years.I am burning slab wood cut and stored since 2019 same with my poplar also cut 2019.I at the moment have wood in racks to be burnt in 2026 &2027 all under roof since the day was split
  12. Farmchuck
    Farmchuck
    Nepa
    Hey I really like those crates! You have got yourself a terrific set up there!Much materials & work in building those crates?
  13. Farmchuck
    Farmchuck
    Nepa
    I’m thinking about coming up with something similar to avoid handling the wood so much, Thanks.:)
  14. Farmchuck
    Farmchuck
    Nepa
    This is very interesting. Approximately how many of those crates do you have built?
    Thanks!
  15. farmer rob
    farmer rob
    [QUOTE="Farmchuck, I have about 30 of them and with that many when I split wood it goes directly into them so only handling after that point is with my tractor.I double stack them so not to take up as much place I also put a number on them stating what year they were split.
    I built them like a 4x6 pallet then put sides on the leaving the front open just put a brace to hold the sides from opening,I would likely do 4 foot high if I was to do it again as they are heavy when full especially with the 3x3 hardwood from the pallets.I need my 100hp tractor to comfortably double stack them as the 70 hp often will be real light on back wheels & any incline requires 4wheel drive
    metalcuttr, Farmchuck and brenndatomu like this.
  16. morningwood
    morningwood
    Home owners insurance is okay with this setup ?
    metalcuttr likes this.
  17. farmer rob
    farmer rob
    Yes
    I did have to change companies as my old one was not even tho the unit is CSA approved for indoor installation.I even had safety guy here last week checking entire property out and he looked funny at it at first but quickly figured out that is legal and installed as it should be.
  18. morningwood
    morningwood
    Mine smokes pretty good when I open up the door. It’s a non air tight building so it’s not that big of a deal. I also installed a fan to suck the smoke out of the top of the building too.
    Please don’t take this as being preachy. If that’s attached to you your house I hope you have a carbon monoxide alarm in there and one in your house nearby. My house is all electric and I have one on each floor of the house, just in case.
    Saw this in the news recently.
    Airbnb's silent killer: Carbon monoxide linked to 19 deaths in 10 years
  19. farmer rob
    farmer rob
    [QUOTE="morningwood, No problem and never preachy.I am not sure if you have a gasser unit of the regular type .I know the none gasser units are not approved for indoor installation as they smoke when door opens from what I have read.my house is new last year so there are hard wired detectors in every bedroom and in kitchen as per code here in Ontario.
  20. Highbeam
    Highbeam
    Also remember that Canada has smarter laws that allow wood burners in garages.
